Question about RCA HD50LPW175 50" HDTV
Atx 300 my power supply (atx 300) would stay on only for a second or two. i checked it and find out that the fan would only rotate for a second or two also. what could be the problem?
  • RCA Master
  • 12,061 Answers
Hi, look with PSU's ya don't muck around... simply replace it with a similar spec'ed one... they are all the same more or less.
The reason it won't go is that it is faulty, OR ya have a Fault on ya MotherBoard that is stopping the PSU from working... PSU's are so cheap these days replacing is much easier and less expensive than repair.
Regards Chris
Posted on Jul 28, 2008
    Genius:
  • 1,139 Answers
Hello wazalac,
This may be the failure of the power supply itself. Did you take voltage readings of the outputs. I would venture to say that the problem is either with the switching power supply oscillator, or the high power MOSFET switch. Check for blown fuses, and if you have a ohmmeter check to see if the high power MOSFET is shorted. You will need a schematic, and a multimeter to do this.
Thank you,
Shuttle83
Does a solid green light mean the power supply is ok when disconnected from motherboard and drives, ATX-300-12Z
Not necessarily. The green light usually just signifies power to the power supply. Amazon sells a cheap power supply tester that can verify everything on a power supply from old to new.
Jul 21, 2014 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Having problems with Bestec ATX-300-12z power supply.
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... This is a common power supply that can be purchased just about any computer retailer - BestBuy, MicroCenter, Amazon.
Very cheaply priced, very functional. Even the generic brands.
Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection.
Nov 14, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Computer shouts down in 15 to 20 seconds after starting
The specs say the PSU is ATX compatible. Whether that is for the connector only or for the whole power supply is something you will have to determine.
If you have an ATX power supply handy (like in an old computer) give it a try. This one is only 300 Watts so it won't likely be expensive to replace.
Have a look at: http://www.techspot.com/community/topics/dell-dimension-1100-shuts-down-after-20-seconds.135987/
Aug 28, 2012 | Dell POWER SUPPLY Power Supply
HP 5188-2655 power supply green light is not solid just light and won't turn the fan on & the computer. What it does mean?
Take the power supply to a retailer or computer shop in your local area to be tested. Pretty standard from what I have found out.
Bestec ATX 300 12Z Rev DDR Replacement Power Supply HP 5188 2625 Have a great day.
Mar 19, 2012 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
MY PC SHUT DOWN NOT WORKING
Try to check the power supply, if the fan rotates as you turn it on, the try to open it and look for the motherboard capacitors there maybe some leaks on it. but if you have a spare or extra power supply try to change it. maybe you power supply brokes.
Jul 12, 2011 | Biostar G41D3 - Motherboard - micro ATX -...
ATX-300-12Z was hit with a power surge (thought we had a surge protector). Green light on power supply blinking at 2X/second. No power at USB devices (or anywhere else.) PC was on when surge hit.
There were 2 Switching power supply circuit inside the ATX PSU. There's a Standy PWM circuit whichSupply +5V to the PWM IC of the Main PWM. Stand by pwm still working or insufficient voltage, lower than +5V. This is the reason you still have Green light. Check or replaced small filter capacitor around 100 MFD 16V, open resistor or shorted diode that was nearest of the PWM IC..
Watch out for charge voltage on big capacitors.
Rleo
Dec 30, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Power supply led blinks but will not power up
My gateway was powered up and I came back into the room and it was not. It would not turn on so I checked the power supply with the paper clip jump method (which is the only thing I know how to do) and the green light along with the fan turns on. While it is plugged into the pc, it blinks with no fan running. The power supply is an ATX 300-12EB3. The Gateway is 556GE. Thank you for any help I can get on this.
Sep 23, 2010 | Gateway Bestec ATX-300-12EB3 305w Power...
Can an ATX-300-12E be used in place of an
I think it wont be a problem as long as both pwoer supplies are of same type e.g both supplies are for P4 sytems
Feb 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I have a Bestec atx-300-12az and i need to know which power supply harness to use on a Samsung model#HD103UJ hard drive.Thanks,Tony
Technical Details
  • Samsung Spinpoint HD103UJ 1 Terabyte SATA/300 Hard Drive General Features:
  • 1 Terabyte formatted capacity 7200 RPM spindle speed SATA/300 interface 32 MB buffer
  • 8.9 ms average seek time 4.17 ms average latency 3.5-inch form factor
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
SATA Power3 Peripheral4 Floppy5 02 +3.3V (Orange)
03 COM (Black)
04 +5V (Red)
05 COM (Black)
06 +5V (Red)
07 COM (Black)
08 PG (Gray)
09 +5VSB (Purple)
10 +12V (White)
11 +12V (White)
12 +3.3V (Orange)
13 +3.3V (Orange)
14 -12V (Blue)
15 COM (Black)
16 PS-ON (Green)
17 COM (Black)
18 COM (Black)
19 COM (Black)
20 Blank
21 +5V (Red)
22 +5V (Red)
23 +5V (Red)
24 COM (Black)', CAPTION, 'Pin Signal (Color)', WIDTH, 150, BGCOLOR, '#000000', FGCOLOR, '#FFFFFF');" onmouseout="return nd();" href="javascript:void(0);">matx24pin.gif
atx12v.gif sata.gif drive.gif floppy.gif This ATX12V power supply is a 300W, five output unit with remote on/off, and UL, CSA, and TUV approvals. RoHS compliant. Original HP part number 5188-2625 used in many Media Center, Pavilion, and Presario computers. Also serves as upgrade for HP/Compaq part numbers 5189-3964, 5188-0131, 5187-5116, 5187-6114, 5188-0129, and 410507-001. Airflow drawn out of case into surroundings by 80mm internal fan. Built-in power status LED above AC inlent. 2 x 12 (24 pin) main board power connector. Includes two daisy chained Serial ATA connectors. Bestec model ATX-300-12Z CDR, also replaces ATX-300-12Z BC, ATX-300-12Z BD, and ATX-300-12Z CC. i trust this helps
Jul 15, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
I have a okia 500atx power supply. When I attempt to turn on the computer, it will stay up for about 3 seconds then turn off. is the power supply the problem?
CHECK THE FAN REMOVE ANY DUST AND SPIN THE FAN PLUG IT IN AND TURN IT ON IF SAME PROBLEM THAN THE FAN IS BAD IN THE POWER SUPPLY AND YOU NEED A NEW POWER SUPPLY TAKE IT WITH YOU WHEN YOU GO TO THE COMPTER STORE FOR A NEW ONE
CANDYMANGANDY
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
RCA HD50LPW175 50" HDTV Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
