Question about HP PSC 2110 All-In-One InkJet Printer
Can the "align cartridge" requirment be stopped
I have an HP210 and evertime I change an ink cartridge, it requires me to realign teh cartridge. This is a pain since usually it happens right in the middle of something important that I am printing. Can this be terminated / bipassed so that I don't have to align it?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
I know it is quite frustrating. Let me help you in this regard.
Before we move, let me inform you that whenver, you are trying to insert a new cartridge into the printer, the printer would be detecting the cartridge and prompts for alignment. SO, I suggest you to go as per it and however, if you want to bypass the alignment you have the following steps.
Press Setup and Options (or Copy Options) simultaneously when align message is prompted on the All-in-One.
Regards,
Sagar
Posted on Jul 27, 2008
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
Print colour not consistent
The single item in an inkjet printer that requires the most attention is the ink cartridge and usually is the cause of uneven, light and inconsistent printing problems. When such problems happen usually the ink cartridge needs to be replaced, but sometimes you may need to inspect the ink cartridges for problems. Ink cartridges can be popped out of the printhead assembly for inspection of the inkjets. if any or all of the jets are clogged, it is possible to clear them by gently wiping the face of the cartridge with a swab. A gentle squeeze of the ink reservoir can also help to unblock the clogged jet.
Hope this helps
Dec 10, 2010 | HP DeskJet 970cxi InkJet Printer
The carousel the hold the ink cartridges seems "locked" to teh right and I cannot get access to remove and replace the cartridges. Please help
go to "printer properties" and click on "maintenance". Click "change cartridge" then follow the steps described there.
good luck
LC1000
www.inkbank.com.au
Dec 08, 2010 | Epson STYLUS CX5900 Printer
I replaced the color cartridge with a new one. The new cartridge was the wrong size. I placed the old colour cartridge back in the printer and now the printer will not work. The ink drop for the colour...
Hp is known for being a pain with ink.
We once had a business jet that would not print because our ink had expired lol...
The printer wont work because it know's that the old cart has no ink. And since it needs all three colors along with black to print it will not do it, Usually you can set the printer to print only black under properties or print settings.
Other then that you will need another cartridge. You can also try one more thing. If you need to print in a Pinch, down on the right hand part of your screen, Is the clock. Double click it and change the date back a year from today and see if that helps you print
Oct 06, 2010 | HP Deskjet 6980 InkJet Photo Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Need to change my ink cartridges....don't understand how to get the old cartridge out and put the new cartridge in.....help....
Most cartridges lift forward and up. There is a slight catch that you will have to get past, but that isn't very hard to do.
To get to the cartridges, open the lid and teh ink should move into position for you.
Make sure you put the same color in the right spot.
Dec 12, 2008 | HP PSC 1315 All-In-One InkJet Printer
I have forgotten how to change ink cartridge
There is a door on the front of the printer on the right corner. There is a little tab thingy on the side of the printer that you use to pull the door open. This you can do from the front, you don't need to move the printer around to get access from the side.
Pull the door down and tada, there are the ink cartridges. What a pain in the ****, took me a good 1/2 hour to find the information on the internet.
Hope this helps everyone.
Tracey
Nov 27, 2008 | Office Equipment & Supplies
Not printing - Flashing lights!!
If the following happens to your printer from canon's support page i found these:
"Issue: Power light (or Alarm and Power lights) alternate(s) between orange and green
Solution: The i350 may require repair
Unfortunately, the issue you describe seems to indicate that your product may require repair service. If you feel your product might require service, a Technical Support Representative will be happy to answer any questions you may have and explain the service options available to you. You can contact us through the email link or phone numbers listed below."
Nov 23, 2007 | Office Equipment & Supplies
HP PSC 2110 All-In-One InkJet Printer Logo
286 people viewed this question
Ben Johnson
