Question about Microsoft Windows XP Professional
To dispaly row without duplication
Hi !
Plz solve my problem,
there is a query table (query) in this tabel there sare so many rows that contain one rows more time like 5 time or etc.
now i want to retrive a row from it without retriving all rows but i want to retrive that duplirow one row so plz give me the access query that display the same rows one time.
thanks for help.
    Problem Solver:
  • 44 Answers
Mini-05,
Try something like this:
SELECT DISTINCTROW Serial.SerialNumber, Serial.ID
FROM Serial
WHERE (((Serial.ItemID)=[CurrentItem]) AND ((Serial.Sold)=False))
ORDER BY Serial.SerialNumber;
Posted on Aug 05, 2008
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    What is vlook up & what is hlook up?
    The VLOOKUP and HLOOKUP functions contain an argument called range_lookup that allows you to find an exact match to your lookup value without sorting the lookup table
    I have posted below link to know more .Please have a look..
    http://www.howtodothings.com/computers-internet/how-to-use-the-vlookup-and-hlookup-functions-in-microsoft-excel
    http://support.microsoft.com/kb/181213
    http://office.microsoft.com/en-us/excel-help/vlookup-HP005209335.aspx
    http://www.timeatlas.com/5_minute_tips/general/learning_vlookup_in_excel
    Please rate & vote if you like soution..
    Thanks
    Sandeep
    Mar 14, 2011 | Microsoft Excel for PC
    Plz tell me Sir/Madam. what is Hlookup And give me example
    Hi Geetad11
    This is Horizontal lookup , used to look up value in a 2 dimensional table .It searches for a value in the top row of a table or an array of values, and then returns a value in the same column from a row you specify in the table or array. Use HLOOKUP when your comparison values are located in a row across the top of a table of data, and you want to look down a specified number of rows. The H in HLOOKUP stands for "Horizontal."
    Formulae Syntax
    HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)
    Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string.
    Table_array is a table of information in which data is looked up. Use a reference to a range or a range name.
    • The values in the first row of table_array can be text, numbers, or logical values.
    • If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted.
    • Uppercase and lowercase text are equivalent.
    • You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
    Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
    Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
    Remarks
    • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
    • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
    Example
    The example may be easier to understand if you copy it to a blank worksheet.ramsoft.jpg
    Oct 06, 2010 | Microsoft Excel for PC
    Access database was copied now no tables in dropdown list
    Your version of Access may require slightly different menus and clicks than mine, but the procedure is straightforward and should be very similar to what you will need to do. Read the whole post first!
    Make sure you have permission to modify the database, then go to the form (I assume the drop-down table is in a form) and go to design view.
    In design view, click once on the dropdown box you are having a problem with, and a properties screen with several tabs should pop up; click on the data tab, and look at 'data source'. In the list look for 'row source type' to see if the source of your data is a) a table or a query, b) a value list or c) a field list. Most dropdown boxes use either a value list or data from another table or a query (based on a table).
    Check the source of data by going down to the next line in the list titled 'Row Source' (this is the list on the data tab that popped up when you clicked on the dropdown box in design view).
    If the source is a table/query type you should see some code in the Row Source box like "SELECT....". Without changing anything, click once immediately to the right of the box, and whatever source the rows are coming from should pop up--if a query, for instance, it will pop up the underlying query in design view.
    You should be able to troubleshoot the underlying query to see why no data is given in the dropdown box.
    Another point where underlying query or table is used: If the table was based on a query that pulls data from the records in the current database, the drop down list will be blank until new records are added so the query has something to list.
    And if the source is a 'value list', the values should be included in the row source box below, separated by semicolons. If not you simply need to add them in.
    If your source is a field list, go back to whomever copied the database and tell them you need help with the copy they gave you...
    Sep 13, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
    HIGHLIGHT THE CURRENT ROW
    Hi Rakesh,
    in MS Access 2003/2007, the first record is always highlighted in table as well form's text controls when they connected to a database. In a query cursor is always at last record.
    In flex-grid control you can set its properties to get cursor on a particular records.
    I think your problem is solved.
    Please contact if not.
    Zulfikar Ali
    Mar 07, 2009 | Microsoft Access 2003 for PC
    Linking tables in Oracle
    While I'm not saying it's not possible, it's not something Oracle (Or any relational database) is designed to support, so don't be surprised if this isn't possible or extremely difficult.
    Relational databases support predictable relationships. IE: Table 1 relates to Table 2 in a given way.
    Relational databases do not support varied relationships depending on the data in each row. The query engines simply can not join data this way.
    If you provide me more details about your data, I might be able to propose a table structure that doesn't require a different table for each row of data in ROOT.
    Feb 12, 2009 | Microsoft Computers & Internet
    HLOOKUP IN MS EXCEL
    lookup value = value searched
    table array = database
    topmost row of lookup array must contain the data IDs and all IDs must be sorted in ascending order.
    row index number = row number containing data to be shown; first row = 1
    hlookup(x,tablearray,y) will look for x on the first row of the lookup table and return the value in the cell on the yth row
    if formula cannot file exact x, it will look for the value closest to. but not greater than x
    Nov 13, 2008 | Computers & Internet
    Formula required
    at first select the 1st page data and select data-subtotal from the upper menu list.
    then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
    If not solved pls get me that data as to reference.
    thanks
    Dec 04, 2007 | Microsoft Excel for PC
    Budgets in excel
    Dear Madiha35,
    I would recommend the use of the Table Function in Excel.
    Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
    Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
    Excel 2007 had a budget format workbook
    New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
    Step 1:  Enter your data into the worksheet.
    Step 2:  Create Table
                 Highlight the relevant data
                 On the insert tab, click on Table
    Step 3:  Verify Table range is correct, Click OK
    Step 4:  Select the cell you where you wish to Sum Data.
             Click on Autosum.
    Step 5:  To Insert new data
             Click on the sum row in the table, (Not the entire worksheet row)
             Right click, Insert, Insert Table rows from above
    Step 6:  Enter new data in row
    Step 7:  Data is automatically calculated in formula.
    Oct 22, 2007 | Computers & Internet
    Microsoft Windows XP Professional Logo
    244 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
