I have an HP Color Laser 1600/ On printing, usually after now using it for a few days 8 cm (right side) I get a jagged/ white streak/skid as though the the ink has been smeared before it was fused. It is rough to touch on the edged. Warwick Any clear Sane on colour ad black, byt
Just wiped the area inside the feed tray
Posted on Jul 27, 2008
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
Is there a way to get rid of horizontal streaks?
1) Inspect, clean and reinstall print cartridge.
2) replace the print cartridge
3) Replace the charge roll assembly. Some call this the fuser assembly.
Aug 15, 2014 | Dell 5130cdn Color Laser Printer
HP Laser Jet 4700n-Light printing on right side of paper. Removed all cartridges and toner, cleaned and recalibrated after start up. Still light printing on right side. Any suggestions??
Is the light printing the same for black and white vs color? Light printing on a side is not uncommon for these printers. It is usually caused by the laser optics getting dirty. But this usually shows up more in one color than the other. Such as something printed in yellow is fine while red is faded on one side. If the light on the right side printing is the same on all colors including black then I would suspect something with your transfer unit.
If you do notice that it us just on black or another color then it is definately time to get the laser optics cleaned.
Dec 18, 2009 | HP LaserJet 4700N Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Setting default
  1. Go to START>PRINTERS AND FAXES
  2. Right-click on your printer and choose "Printing Preferences".
  3. Choose the Color tab and set it to "Print in grayscale"
  4. You can also set it to use the b&w cartridge only for true black & white prints.
Jan 17, 2009 | HP PSC 1600 InkJet Printer
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
White streaks in print outs
Check transfer roller, or change black cartidge, if it only happens to the black then there is something wrong with that part of the process.
Oct 22, 2007 | Ricoh Aficio CL2000N Laser Printer
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
