Question about Nikon D70s Digital Camera
Nikon d70s my camera cf card is showing FOR all the time when the card is inserted.
    Problem Solver:
  • 8 Answers
The card may have pushed the pins through the back of the circut board inside the camera (a semi common issue) or they may require cleaning (with some contact cleaner or rubbing alcohol in a q-tip/cotton bud).
Check for corrosion and/or damage to the pins.
Also, and this may soud stupid, shake your CF card to check for loose internals whcih would indicate damage to the card.
My camera sporadically gave card errors then would flash "FOR" without me pressing anything and would result in corupted image files. This was due to por pin contact caused by a damaged CF card (caused by my dodgy card reader) but in your case the pins or card may be damaged causing a poor connection.
The only solution I have found is purchasing a new card as my pins were ok but my card was damaged. Your situation may require a clean and service and/or repair to the pins.
Posted on Aug 13, 2008
The cf card slot not working
Look inside the slot...are any of the pins bent?
Feb 16, 2010 | Nikon D70s Digital Camera
CHA display were the counter numbers are
CF Card reading error.  Usually cheap cards, can be bent/tarnished/worn pins inside D70, this part can be replaced.
First read:
http://www.vandyll.net/?p=499
Then read
http://www.stephanmantler.com/wordpress/d70s-camera-repair/en/
Nov 14, 2009 | Nikon D70s Digital Camera
CHA appears in window and camera will not work at all
The very first thing which you should try is another CF card. Preferably a brand new one (not Lexar 80x, see below), but if not then use one which has been freshly reformatted in another Nikon DSLR.
ziggy53 on the Digital Grin forum posted an answer to this question two years ago. As I cannot put it any more clearly or succinctly his posting is reproduced as follows:-
"It appears that a Nikon D70/D70s CHA error is a general "cannot writeto card" error and can be caused by many different situations including:
1) CF card fault/failure
2) CF card fragmentation
3) CF connection, camera contacts
4) Camera internal failure with card write circuit board
5) Power supply in camera, potentially also related to the battery.
To rule out the Compact Flash card(s) as the fault, try a brand newcard (not Lexar 80x, as those seem problematic), format in camera anddo not field erase images. Reformat card in camera to start over. Ifthis procedure works, format the older cards in the camera and thenwork the cards by taking images, preferably RAW to fill up the card asquickly as possible. Do not completely fill the card but stop at around10 remaining images and format the card in camera once more. You mightbe good to go.
If these procedures don't work, it is recommended to return the camerato Nikon for a checkup. If Nikon cannot diagnose a problem, you mighttry a new battery as some claim a weak battery to be part of theproblem, but I don't see that "cure" mentioned often enough to know ifreally is a cure or not.
Repairs for an out-of-warranty repair for the problem relating to thecamera seem to run around $300USD from those few folks who reported acost."
All credit to ziggy53 http://www.dgrin.com/showpost.php?s=e7ff151930f88761a5feaa2e0348446c&p=710857&postcount=8
I've experienced this problem on a few D70 and D70s models and the advice ziggy53 gives has proven to be right on the mark; to Nikon's credit I've also found that in every case where I've definitely eliminated the possibility of a CF card failure they have attempted out of warranty repairs on a goodwill basis: all I had to pay for was for tracked and insured shipping to Nikon and they paid to return them. Of the five or six cameras which I've sent back so far only one had the problem re-emerge albeit in a less serious and very infrequent form. By then I'd given the camera to my niece and she's decided the fault is not serious enough to warrant sending it back again.
Oct 06, 2009 | Nikon D70s Digital Camera
CHR problem Of Nikon D 70S
problem in card holder replace it
Jul 05, 2009 | Nikon D70s Body Only Digital Camera
Can a SDHC card be used with a CF card adapter in Nikon D70s?
You would have to get an SDHC to CF adapter which could be pricey and they are hard to come by.
Dec 31, 2008 | Nikon D70s Digital Camera
Nikon D70 digital camera memory card cannot be used
First read:
Then read how, with pics:
Careful now....
Dec 09, 2008 | Nikon D70s Digital Camera
Nikon D70s Problum
Why did you buy 8, wouldn't one be good enough?
You've have purchased some defective cameras.
How much did you get them for?
atdlee@netzero.com
Jul 07, 2008 | Nikon D70s Digital Camera
Error CHR in D70s
try another cf card first. if the trouble is still the same,  there is an internal malfunction in the unit, you need pro fix then.. [:0(
Oct 11, 2007 | Nikon D70s Body Only Digital Camera
Nikon D70s Digital Camera Logo
54 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
