Question about Dishwashers
Whirlpool APD5550 Dishwasher, cycle does not start, green light on start button flashes 6 times, pauses, flashes 6 times etc. can you please give me some indication what the problem may be. Thanks
  • sternwood Nov 23, 2008
    cycle starts then stops and start light flashes. Pressing button and holding restarts machine.
5 Suggested Answers
SOURCE: Whirlpool dishwasher not working
appl_doctor solution # 1 is the fix worked for me. Thank you very much appl_doctor
Posted on Feb 19, 2008
SOURCE: Whirlpool dishwasher 6th sense, model no ADP7406
how does the wash nosel fit in
Posted on May 30, 2008
  • 65 Answers
SOURCE: whirlpool dishwasher
Do a "key dance" between normal and heated dry , going bak and forth six times. this will rester the heater fault. That is the clean light flashing code. Now you have to find the cause. Most likely is that there were suds in the last cycle or the door doesn't close smoothly. If the door sttrikes the cabinet in any way it will cause that problem.
Posted on Nov 03, 2008
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Posted on Jan 22, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Have a Whirlpool Dishwasher 6ADP 5540. Starts cycle - fills water then about a minute into it the start buttons flashes 6 times and will not continue on. Very rarely, the cycle does continue on. Have...
Hi Jodie,
An F6 fault code - indicated by the green light flashing in sequence next to the start button - is indicative of a water inlet problem.
First of all check that the water tap the dishwaher connected to is fully open. If this does not work check that the feed pipe from the water source to the appliance is not blocked.
If neither of these two things are the problem then you will need to order a new flow meter/ reed switch and this will sort your problem out.
The Whirlpool UK spare part number you'll need is 481241868368
Hope this helps
Alex
Jan 14, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
My dishwasher isn't working. The clean button
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats this occurs when the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dec 29, 2007 | Dishwashers
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
