Question about Toshiba 50HX81 50" Rear Projection Television
Thanks for the reply
So caps on the hyperboard. Hmmm...I don't know what a hyperboard is so that could be a problem. Where did you buy the caps? Maybe I'll have to try that as well. I was planning to sell the TV for $200 since it doesn't work correctly but if I can fix the problem cheaply then maybe I can get a bit more for it. Do you have any other info that might help me?
  • phx_sis Jul 27, 2008
    That seems a little too difficult for me. There's no way I'd be able to solder anything. Thanks for the help though! I guess I'll just sell it for as much as someone will give me for it.
  • bishoppe1 Jan 27, 2009
    my 50" wide screen was purchased in 2002. it ran fine until i added the hd converter box from comcast. the image on non-hd channels started to jump, pixelate and the sound stutter occassionaly. now it is unreadable on startup and the hd channels are starting to become effected too.
  • 4 Answers
Look at this thread.A lot of info there. I have ordered the caps at digi-key.com, part # 493-2105-1-ND
http://espnhd.com/voice/showthread.php?s=372087d540bc5c4b9b4d68631c67b610&t=10984&page=2&pp=20
Posted on Jul 27, 2008
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
Replacing 10up @16volt caps on toshiba hyperboard help toshiba 42
They are just little box reservoirs. Heat them up and pull it out when hot. Heat it up again and set the caps in the hot solder box.
Charles
Jan 09, 2009 | Televison & Video
GO 720 EAST EUROPM MAPS ACTIVATION CODE
Hmmm, and you did BUY that map through TT Home?
You could allways try here:
http://www.ttcode.com/
Apr 01, 2008 | Tomtom GO 700 GPS Receiver
Hyperboard repair Toshiba TSB
Best way is to check in circuit with ESR meter........
EDS-88 CapAnalyzer..... www.eds-inc.com .........................
Mar 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hd82 Hyperboard
By your question alone the best place to start would be a good repair shop. The hyper module needs to be removed from the main chassis. After removing the two outer covers locate Cx261, Cx230, Cx270, Cz52, Cx178, Cx221, C514, Cx250, Cx670, Cx241 and Cx541. These are all 16v/10uf caps SMT but most techs simply replace them with the sub mini radial caps.
Bill
Mar 13, 2008 | Toshiba 50H72 50" Rear Projection...
Wavvy lines, wiggy
Dougers, I am next door, in Alberta. I have fixed my hyperboard by replacing the surface mount caps myself in my workshop for a fraction of the cost of a replacement board.
See my other thread for more information.
Oct 23, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 50h13 hyperboard
http://www.hdtvoice.com/voice/showpost.php?p=122387&postcount=7
Oct 16, 2007 | Toshiba 50H13 50" Rear Projection...
You need part #23148024.  The part is NLA.  I have 1 in stock or you can send yours to PTS electronics 800-844-7871 for rebuild.
Oct 15, 2007 | Toshiba 42H83 42" Rear Projection...
65H82
what you did forget you just tell what is your problem now clearly so i can help you in a systematic way.
Sep 08, 2007 | Toshiba 36HF72 36" TV
Toshiba 50HX81 50" Rear Projection Television Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
