Home | HP | PSC 750 All-In-One InkJet Printer | Clogged inkjet ports on ...
HP PSC 750 All-In-One InkJet Printer
Problem for HP PSC 750 All-In-One InkJet Printer
Clogged inkjet ports on an hp psc 750xi
By t_zieglerjr on Jul 27, 2008
I tried printing a document on the printer and got blank pages as a result. I tried using an old toothbrush to unclog the jets, but this only worked for about fifteen pages. I still need to clean the ports so I can print again.
Best Solution
posted on Aug 27, 2008
Very Helpful)
denkile
Rank: Apprentice
Rating: 100%, 1 votes
UNCLOG INKJET PRINTHEAD NOZZLES
Soak the printhead in hot water ! It works !!
_submerge printhead in aprox 0.1 inch water in plate
_hot water from faucet.... heat plate and water in microwave
_do not exceed 160 F or too hot to touch
_soak until ink comes out in water...
....usually a minute is good enough...sometimes 15 min
.....if it works and then goes dry soak some more
ALSO
CHECK THAT THE CARTRIDGE HAS INK by postal scale weight or by feel.
Compare to known full and empty carts....ink is about one ounce
and empty cartridge 2-3 ounces.
RESET REFILLED CARTRIDGES
Google search: reset C6578 and reset c6615 and find
http://www.refill4.com/refillinstructons/hewlett-packard.htm
If this donotwork search and try the other resets.
RESET THE PRINTER'S MEMORY FOR THE USED CART
I am still trying to find an effective way to reset the printer memory..
....'maybe remove the CMOS battery on the pprinter board
if I can figure out how to get at it.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Are there screws or other means the print head is attached to the rail? How do I disengage the print head?
Popular Solutions for HP PSC 750 All-In-One InkJet
Questions and Unsolved Problems for HP PSC 750 All-In-One InkJet
Do you recommend HP PSC 750 All-In-One InkJet Printer?
Answer
Answer
the scanner will not scan it will copy and print
Answer
Why won't my psc750 print word pad or off of the internet, but will print microsoft works. It is... (More)
Answer
when I print the paper don't kick all the way out of printer
Answer
I replaced my hp psc 750 black ink cartridge with a new hp cartridge and keep getting error... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP PSC 750 All-In-One InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
