Question about Acer Computers & Internet
The laptop fell while the power lead was inserted it pushed the pin to the side an stopped charging it now wont turn on
    Problem Solver:
  • 19 Answers
Replace the power supply or the motherboard of your laptop, if your laptop still has its own warranty try to call the technical support of your laptop manufacturer and asked them to replace your power supply or motherboard. But if you dont have any warranty from your manufacturer, you must still call them to purchase a new power supply or motherboard.
Posted on Jul 27, 2008
Why won't my camera turn on or charge?
Battery may have died suddenly, as they can ! If charging from mains lead , check fuse , if charging from USB lead , check lead, connection. Re set camera , or take battery out, then re insert and try again to charge battery
Jun 08, 2015 | Panasonic HX-WA10 HD Camcorder - Blue 16MP...
Turn signal switch repair
The steering column wheel has 2 pins pushed into the back side of it and as you turn the steering wheel making a turn, the pins slide over the humps of the blinker signal. As you return the wheel back to center to drive straight, these pins then hit the humps in the turn signal and push the turn signal back to the original position. It sounds like one of these pins fell out or broke off. You need to pull steering wheel and check to see if these pins are still inserted on the back side of the steering wheel.
Sep 29, 2013 | Mitsubishi Montero Sport Cars & Trucks
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
May 04, 2012 | RIM Blackberry Playbook 7Inch Tablet...
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Jun 08, 2011 | Sony Computers & Internet
Power button on laptop is completely pushed in/caved in
insert safety pin to the side of button and slowly try to pull it out
Sep 29, 2009 | Gateway MT6840 Notebook
Samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
Hp nc8000 power issue
Many of the power jacks also contain switch contacts that allow the adapter to power both the laptop and the "charging" system. I would suspect that one of the leads had either been broken or at least detached from the pc board. This laptop needs to be dis-assembled and the power jack repaired. Worse case will result in the replacement of the jack or the repair of the board if that part has been cracked.
May 13, 2008 | HP NC8000 (DE503AV) DVD+RW Burner
Advent 9912 wont turn on
remove the ac adapter
take the battery out
be sure nothing is connected with your laptop
then press and hold the power button for 60 secs to drain static as it is the most probable reason laptops stops working.
then connect the ac adapter only and without the battery try powering on the system
if it powers on
you can again shut it down
insert the battery
it should surely power on
Apr 20, 2008 | Dell 2600 Notebook
Computers & Internet Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
