Question about Zenith R57W46 57" Rear Projection Television
My TV screen has 3D problem
Every word on the screen is appearing twice, or in two parallel line. one completely red line won't go away, how can you help me?
my TV is Zenith made 2003, model # R57W46
  • 4 more comments
  • Anonymous Jul 29, 2008
    Problem: Convergencies IC. STK 392-120
    When removing the back cover you will see them in the left side.
    If you have soldering skills, probably you can change them. If not I recommend find someone that can do the job. After de STK are changed, it's necessary convergency adjustment.Good Lock
  • dddy04 Aug 23, 2008
    I have a Magnavox tv the screen look like 3D projection with a red line
  • Anonymous Sep 29, 2008
    HI, I have a sony flat screen tv. I see 3d on the screen. Everything appearing twice or even triple. Is this the same as the Zenith problem?
  • Anonymous Dec 20, 2008
    i have the same dam problem guy
    i have the same friken problem
  • Anonymous Dec 21, 2008
    We have red and green screen but we want to know execty what to do to fix it or what part i need to replace.
  • 556 Answers
You need to have someone replace the convergence IC's
Posted on Aug 20, 2009
PS3 3D TV Display Doesn't turn on 2 red blinking lights
HI, in this video you will find how to fix your Sony 3D Display
https://www.youtube.com/watch?v=OdPGSZnTIPw
Dec 02, 2012 | Sony PlayStation Televison & Video
Red vertical lines on right side of LED TV set
It is likely the main board that processes all signal to and from the display panel (entire front screen unit).
It is also possible it is the display panel itself which is fatal.
May 16, 2012 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
I have dell vostro 1014 laptop. there was a vetical line appeared on its screen of green colour 3 days ago and graduaaly more vertical lines are appearing of red colour.what should i do please help me....
press the back of it & you'll notice they will go away let go & they come back.
the screens bent either way you look at it you need a new screen.
i've tried to fix this problem twice before & twice i've cracked the glass trying to straighten them.
now i just put a new screen in them.i'll do it cheap click link:
T-ComTech Computers
Sep 30, 2010 | Computers & Internet
My tv looks like it is in 3D without 3D glasses,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red vertical line appears intermittently
you have to have the entire screen replaced. hitachi tried to fix mine twice and couldnt, i finally took them to court and won. want my advice? get a new tv and never by a hitachi again!!! they are the worst!
Jan 23, 2009 | Hitachi 55HDX61 Television
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
Apr 21, 2008 | Philips 42HF7444T 42 in. Plasma TV
RCA 52" TV
Here is your other post.
Feb 25, 2008 | Televison & Video
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Jan 30, 2008 | JVC AV-56WP30 56" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
418 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
