Question about RCA OPAL M4001 MP3 Player
Wont come on
Everytime i try to turn it on
it says its building the database.i made sure the hold button
wasnt on and it still wont work. is there any way your could help
me??
  • 159 Answers
Your firmware is mostly likely bad.
Go here
http://www.rcaaudiovideo.com/
do a search for you make and model.
Download the firmware.
Then plug you mp3 in your usb of you'r computer
Install the firmware.
Posted on Jan 16, 2009
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
Loading and saving doesn't work.
rebuild the file system and the database in the recovery consol.
to get to the recovery consol
when ps3 is in standby(red light) press and hold the power button till you hear a double beep then release. if the light turns red before the double beep quickly release and hold it again and wait again.
my ps3 goes like this
ps3 standby mode...press hold power button......."beep"......"beep"........standby again..release then hold real fast........."beep".........."double beep beep"....release and there are the options to rebuild database and filesystem. database and file system wont delete saveed files. i have some other tricks so let me know but try this first.
Sep 19, 2009 | Sony Playstation 3 (PS3) Console
My mp3 will turn on,but then it will say "building database",and keep on doing at...it wont shut off,and i tried resetting it manually,but that doesnt work
You can try updating the firmware for the mp3 player, if available/applicable. You can also try pressing the reset button on it or reformatting it completely.
Jan 03, 2009 | SanDisk Sansa m240 MP3 Player
RCA M4004a MP3 player problems
mine was doing the same thing. It was on "hold" - a little button on the side that i didn't even know was there. I took it off hold and it is fine.
Apr 04, 2008 | RCA M4004 MP3 Player
Sansa e260 wont "boot"
Sometimes the sansa players take an extremely long time to build a database of the music when you put new music on the player.
Try turning it on and just letting it sit for an hour. Come back and see if the player works.
If that doesn't work, plug it into the computer and use the software that came with it to format the player. Load a small amount of music on it, and see if the player can play that.
Good luck.
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Wont start!!
This will take care of it.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e260 MP3 Player
REFRESH DATABASE????
drop it on the floor from about 3 feet high. thats wat i do
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
It wont turn on
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 01, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
Continous refresh database
I've got the same problem too. I read this on another website: 'well firstly drain the battery and then connect it to charge it up a bit. once it has been there for 5min or so take it off and then turn it on>settings>USB Mode>MSC once you have done that connect it up and it should work/recognise the player. i don''t know how this thingy happens but this is just how i fixed mine!' I'm gonna try it now on mine, and see if it works. I've just got to wait now... Good luck with yours.
Apr 10, 2007 | SanDisk Sansa e250 MP3 Player
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
