1990 Honda Accord Logo
Anonymous Posted on Feb 21, 2011
My 1990 Honda Accord radio antenna motor functions opposite to what it is suppose to be. When radio is on the antenna down, when the radio is off antenna up. Even with this reverse function I can feed the antenna into motor but will not go all the way. Do I have to cut the plastic (teethed) cable off for proper fitting? I have purchased a new antenna from Honda. The motor does not have any broken parts of the old antenna in it. Is there a antenna switch that controls this function and where is it located?
  • Anonymous Feb 21, 2011
    This is a factory radio. Is there an antenna switch in the circuit that could have been affected during a repair procedure? It does not appear to be a grd short. It appears to be a reversed wire in the ignition switch or antenna switch. I have no way of telling due to lack of wiring schematic drawings for that year. The wire to the antenna itself is ok. Thanks
Anonymous
Level 1:
Habit-Forming:
  • Contributor 28 Answers
  • Posted on Feb 21, 2011
Anonymous
Contributor
Level 1:
Habit-Forming:
Answers
28
Questions
9
Helped
13258
Points
76
First of all, is your radio factory or aftermarket? If its factory the you probably have a bad ground or a short in the radio power to antenna. If its after market, then the remote antenna wire is hooked up wrong. Check to make sure the antenna wire is hooked up to the antenna. Good luck
  • Anonymous Feb 22, 2011
    The power switch is in the radio, it is a remote antenna wire from the radio. So when you turn on the radio, the antenna should go up, when its turned off, it should retract. The short is probably in the on/off switch of the radio itself. Sorry. Its funny how cars and electronics dont last forever. You just got a bad switch. Good luck. After market stereos are fancy. Actually, if you remove the radio deck itself, and use a test light to find the wire for the antenna, you could cut it, bypass that all together and install a dash switch to activate the antenna. check out the local salvage yards for a replacement.
tip
Fix A Honda Accord Antenna
Anyone that has owned an older Honda Accord (1990-1998 or so) has probably had a problem with their radio antenna. My problem was actually there when I bought the car. Whenever I would turn the car off the antenna would retract and when it was all the way in it would make this horrible grinding/clicking noise. Eventually it stopped working all together. As I was looking into this problem I found out that it was a very common problem, but one that had a very easy solution. I would say that almost anyone could preform this antenna fix. If you are having the same problems here is how to fix it:<br>
1) Get a replacement antenna mast. You can find them on Ebay for around $15.
2) Remove the old mast by taking off the chrome nut that hold the antenna onto your fender. You might need a small hammer and a punch to get it off. It should be fairly tight. <br>
3) Pull out the old mast. You have to give it a good tug as the end is in there tight. Check to see if it is all there. If some of it is still stuck in the antenna motor you might need to take it apart to get it all out.<br>
4) Turn the radio on then put the new mast into the hole for the antenna with the teeth facing the rear of the car. Push it as far as it will stopping when it won't go in anymore. You don't want to force it.<br>
5) Have a friend turn off the antenna while you guide the new mast in. If it doesn't go quite in all the way that is fine, it will eventually.<br>
6) Re-install the holding nut. <br>
That's all it takes. You can now enjoy your radio again!
Why is this really on my 94 Honda Accord making a clicking noise when I put the fuse in my radio and motor antenna fuse slot my radio wont turn on can you help?
Click? That is usually a starter? Are you sure you are replacing the right fuse since nothing should click with an antenna.
2answers
My antenna on my 1990 honda accord stopped working after I installed a new radio
BAD CONNECTION? DID YOU PLUG IT BACK IN? OR DAMAGE WIRE? OR PULL OUT FROMM BEHIND DASH
Spark plug cables order 1990 Honda accord
The firing order for tha car is 1342 with the No. 1 cyl. at the far right side.[passanger side].
thats for the 2.2 motor ,, here click this link and scroll down a little for a picture of it,,
http://honda-tech.com/showthread.php?t=1260612
2helpful
What is tightening torque of harmonic bal. bolt 1990 Honda Accord
1990 Honda accord
L4 2156cc 2.2ltr engine
crankshaft pulley bolt
apply engine oil to threads (a few drops)
tighten to 159 ft lbs
please rate my answer as I am new
Thanks,
Chris
How to Change Car Attenna on Honda Accord LXI
the antenna comes out from under the finder panel , in the trunk there is a carpeted insert, that needs to be removed in order to access the antenna motor, you can take it out from there. it is easier with the radio off. that way the antenna is in the down position.
Antenna
either way, its a pain in the **** to replace...you are better off getting a professional to replace it. if its a powered....the motor is underneath the dashboard on the left side...behind all the fuses...good luck getting it out. if its just a regular..pretty much the same thing. the wire that connects to the radio goes down through the drivers side front pillar...behind the dash board..and finally down to the radio.
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
