Indesit dishwasher DI620. It has a solid light stuck on program 4. I have turned off the power for hours then turned it back on but it is still on cycle 4 complete?
Any ideas?
Hi, you may want to try looking at all the holes in the spray arms. If you see anything blocking a hole, use the tweezers and remove the stuff. Remove the bottom spray arm and check for items in the water delivery hole.Check the lower spray tower that is connected to the bottom rack. Make sure all rotating parts rotate properly. Look underneath to make sure nothing is stuck in the tower. Remove any stuff stuck that is preventing rotation or clogging the tower.
the heating element is probably bad. i have a idl 600 here in naples italy and it would fill up and go into alarm light 2 and 4 and pump out the water. heating element cost 28 euro and i changed it out. had to change the clamps as well. if you ohm the element it should show about 100 ohms. if it is open its bad. the mother board does some checks and if anything fails it alarms out and drains the water after a few minuts ralph
are you finding water in the filter or is the appliance filled with water,if it is only in the filter at the end of the cycle,this is normal as it is used to condensed the steam after the 80o final rinse which drys the cutlery.if ithe appliance is filled then check the drain hose not partily blocked with grease or partly blocked at the sink if plumbed to there
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
