Question about HP DeskJet F380 All-In-One Printer
HP deskjet 3920
My printer always say "Cartridges have problem"
but i don't know what is the problem..I can't print! and as I've check the connection it is ok..everything is ok..i tried reinstalling the printer but nothing happens...HELP! and in the control panel..under the hp printer icon it says...OFFLINE! help!
  • Anonymous Jan 24, 2009
    my printer is always offline and the green lights always blink!
    PLzzzzzzzzzzzzzz help me. I really need my printer back!!!!!!!!
    Problem Solver:
  • 19 Answers
Hi kenjustify!
Let me help you with your concern.
First lets concentrate on your "Cartridge have problem" issue. That message means that the Cartridge of your printer has a problem (Cartridge - is a part of your printer that contains the ink, you may purchase this separately at HP since you have an HP Printer), it may not have enough ink, or its already broken. Both conclusion that i gave needs the cartridge to be replaced. But if the cartridge was newly replaced, you might try reseating the cartridge.
Lastly, on you OFFLINE issue. Just go to "Printers and Faxes" at the Start menu, then double click on your printer inside the Printers and Faxes window, and Click on "Printer" then select "Connect".
Those steps, will definitely solve the issue.
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Posted on Jul 27, 2008
Hp deskjet 3920 door open error
Open the door, left side above on off switch there is contact for door sensing switch, press that check carriage assm moving right side?.. *if yes insert small peace of paper in it, use it..But if you want to replace the cartridges remove the paper object.** if carriage assm not moving open the upper cover check the switch..
Sep 20, 2011 | HP DeskJet 3940 InkJet Photo Printer
Don't know where the print head is located. All that I see is cartridges on my hp deskjet 3847.
Hi Dear,
HP Deskjet 3847 is a inkjet dual cartridges base printer there is nothing like print head.
Print heads are only in Dot Metrix printers.
Ok for more description about hp deskjet 3847, you may see the manuals from following links..
Manual1
Manual2
I hope it is usefull..
May 10, 2011 | HP Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
My hp deskjet 845c won't print pink. I've tried two different ink cartridges and no pink ink. Is my printer probably on it's last leg? I have also tried cleaning the print heads...didn't help.
Are you using HP factory new cartridges?
If you are using third party or worse, refilled cartridges, that may well be the cause of your proiblems.
Don
Feb 24, 2010 | HP DeskJet 845c Printer
Hp 3920 deskjet printer
Please check for the cartridges and try to make copies.
Aug 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
I am having HP Deskjet 3920 Printer. When i try to print any documents, it will show an error message that " The Triclor cartridge is incorrectly installed" , although still it will print color prints...
Hi Anish, Have u checked the printer cartridges installed properly(i.e., Color in color door and black in black door). and also check the cabling between the system and your printer. and put the papers properly. if the problem again persists uninstall the printer driver and install the latest drives which can be downloaded from the net.
Thanks,
Sriram.S
Chennai.
May 02, 2009 | HP DeskJet 3940 InkJet Photo Printer
I want to istall deskjet h.p 3920
Hi falak,
Here's a link to the HP Deskjet 3920 download page - select your operating system to download the appropriate driver for your system.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=445442&
Also, the user manual for the Deskjet 3920 can be found at the following address:
http://h10032.www1.hp.com/ctg/Manual/c00392271.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | HP DeskJet 3930 InkJet Printer
Install HP Deskjet 3920 printer
Here is download page from HP
HP Deskjet 3920 Printer - Download drivers
Chose language and OS version. After downloading the file, double click on the downloaded file to start printer setup wizard.
Keep printer unplugged when you start installing files.
Sep 03, 2008 | HP DeskJet 3930 InkJet Printer
Deskjet 3920 will not print
Check to make sure the USB/ serial cord is plugged all the wat in on the back of the computer tower and the printer itself.
Oct 06, 2007 | HP DeskJet 648c InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
864 people viewed this question
Seeker5211
Seeker5211
