Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
DELL XPS M140 POWER ISSUE
My Dell laptop won't take a charge through the power supply from the wall outlet. If I plug the power supply into the wall, the green light on the power supply itself comes on no problem. As soon as I try and plug the power supply into the laptop, the light goes out and there is no charge taking place. Thank you for any assistance you can provide. Brendan Ramroth
jujomec375@msn.com
    Problem Solver:
  • 19 Answers
Hi brendanram!
I am claudus_07 and i was a Dell - XPS Technical Support Specialist before so i will be glad to assist you with your concern.
As you said into your post, you tried plugging the AC Adapter to the power source without plugging the other end into the XPS laptop and the Green Light on the adapter is lit. But when you plug the jack on the laptop, the Green light is out. As for my experience on your laptop, there could be a problem with the power supply or the motherboard of your XPS laptop. Because everytime you plug the adapter to the laptop, the green light is going out so it means that the laptop or the adapter is grounded.
Here's what you need you to:
Step 1: Call Dell XPS Technical Support 1-800-624-9896
Step 2: Tell them the issue and the things that youve done.
Step 3: At the end of the troubleshooting, i know that the Technician will either replace the Power Supply, Motherboard, or the Adapter. (if you have a friend that has a Adapter same as yours, you may try to use it just to isolate the issue the Technician will choose from the Power Supply or the motherboard)
Step 4: If the Technician replaces the power supply and the issue still persists, call technical support again and ask them to replace the motherboard, no need to repeat the troubleshooting steps anymore just tell them that youre already done with it. (Dont ask for a system exchange, because i know that they will not give what you want.)
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Posted on Jul 27, 2008
    Brigadier General:
  • 6,966 Answers
Two possible suspects:
the AC cord connecteing the adapter/power supply to the wall outlet. It is possible that the cord/plug junction has an intermittent connection internally. Solution would be to cut the plug away and replace or purchase and entirely new cord;
the power supply itself (the adapter). All points considered, they are often replaced, not repaired. However if you are technically inclined and wold opt for a DIY (do-it-yourself), components to check would be regulator transistor, filter capacitor and/or the regulating 4~8 pin IC.
Alternately, it is also (though remotely) possible that the laptop has an internal short (reverse/over protection diode) soldered directly to the terminals of the power jeck.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell xps m140 press the power button green lights come on then go off nothing ever comes on screen
dead motherboard or power supply or powercord and or battery try another power cord if nothing take out battery and try to start with out battery if neither works then it will need either a motherboard or power supply
Oct 17, 2010 | Dell Inspiron XPS M140 Notebook
My Dell XPS M140 has gone thru 3 power supply/cords in the last 2 months. With a new supply it just makes a loud hum.
try upgrading your power supply, if you're burning through them then theres a good chance that your power demand is higher then the cords are rated for. Replacing a power supply is quite simple as long as you ground yourself to something metal to make sure you don't manage to accidentally discharge static into your mobo. Also make sure that you're at least somewhat comfortable performing this task if not then id personally advise that you find someone who will
Feb 06, 2010 | Dell Inspiron XPS M140 Notebook
The screen resolution on my Dell XPS M140 changes dramatically when on battery power. It's like everything becomes overly whitewashed and bright (so much so I can't use my laptop unless it's plugged in)....
Unfortunately, this is not a fix that you can actually do yourself. The actual battery circuit is not functioning correctly.
The transformer is supposed to regulate the amount of power running to the components, it is working, but only on AC.
It does need to be taken in for repair.
Sep 13, 2009 | Dell Inspiron XPS M140 Notebook
How many ways can i break this
most likely cause of death: motherboard charging circuit. there isn't a simple way to fix this one, i reccomend you get a new motherboard.
Sep 09, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Xps m140 want higher resolution displayed tonew secondary monitor
Notebooks usually don't have high res . They trade off the high resulation  for the small size and less power consumption.
Mar 07, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
DELL XPS M140
One of three things, 1- power supply, check your power supply with an ohm meter to see f it's getting the proper output to the machine. If the supply is starving the machine of power the charging system won't work to it's full potential. 2- the power management system on the motherboard, if this system isn't working properly it can divert power from the charging system. If it's just glitched then a bios download or chipset utility download will fix it, if it's malfunctioning, then motherboard replacement is the only option. 3- the battery itself, I have a Dell, and in the past two years, I've ordered two new batteries. The first held a great charge, more than three hours, but only lasted about eight months. The second only holds little more than an hour charge, but has lasted well. Batteries are just funny that way. Start with the power supply test.
Aug 23, 2008 | Dell Inspiron XPS M140 Notebook
Computers & Internet Logo
1,461 people viewed this question
Alun Cox
