Your battery is dead. Try to recharge it. If the light in your USB cable is solid red, then the battery is recharging. If it's solid green, then it's fully charged. If the light is flashing yellow, then the cable needs to be replaced. If this doesn't fix the message, then you will need to send the camera into Samsung and have them repair the camera.
SOURCE: I plug my Samsung SL50 into the usb and my camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
