Question about Vivitar ViviCam 3615 Digital Camera
Locks up after plugging into a PC
My Vivitar ViviCam 3615 locks up after I plug it into a PC. Can get pictures off of it fine on the computer, but after I unplug the camera from the computer, the camera locks up and won't even turn off!. I have to take the batteries out to get it to turn off.
  • 2,071 Answers
If your camera is still under warranty, the best thing you can do is to take it to the nearest official repair shop and Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Vivitar refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Vivitar Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 06, 2008
My camera was doing all things fine until specials moments i needed it. It keeps saying card protected everytime i press the shutter button. Whats wrong with it?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 04, 2011 | Vivitar ViviCam 3615 Digital Camera
Download software for camera Digital camera 1600 x 1200 ViVi cam 3615 S/N V210240900436
http://www.vivitar.com/products
Click on the Vivitar Experience Software link.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Apr 28, 2011 | Vivitar ViviCam 3615 Digital Camera
Camera says working properly. But cannot find how to upload pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Jul 22, 2010 | Vivitar ViviCam 3615 Digital Camera
How do I get my disc out of my Vivitar Vivicam 3615? I know where it is but can't seem to get the disc out of the camera.
If it is like most digital cameras nowadays, you will need to push the card inward. You will feel spring down, click, and then when you release it, it should come out slightly extended, enough so you can grab it with your fingers.
To insert, just place the card back in, push it inwards until the click, and then it will lock into place.
Good luck.
Jul 14, 2010 | Vivitar ViviCam 3615 Digital Camera
Card locked
SD memory cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 06, 2008 | Vivitar ViviCam 3740 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Vivitar ViviCam 3615 Digital Camera Logo
79 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
