Question about Philips 60P8341 60" Rear Projection Television
Tv repair where is this located on the tv and what does it look like
  • Philips Master
  • 8,617 Answers
I have no idea on what youre needing, unless you respond to the origional post I have no way of viewing previous posted info. Could you please state what it is that you need help locating?
Posted on Jul 27, 2008
My Philips LCD 55PFL5706?F7 got wet and I cann't turn on, how ca I fixed it?
Contact the authorized service center for Philips. Never switch On this TV; until it have been checked by the experts at Philips.
Electro help
Jan 26, 2015 | Philips 55PFL5706 LCD TV
47" 1080p
The location should be on the left side,and right side. if the TV is face down and the stand is next to you. If your TV has sound and no video, you are correct that the inverters are bad. Part #6632L-0486A/6632L-0487A. Thanks for asking, Matt of Martins TV Repair.
May 22, 2014 | Vizio VO47L 47 in. LCD TV
Flyback transformer
Throw the set in recycling and buy a new set, its not worth repair, the part would be close to 100 bucks if it was available
Dec 18, 2017 | Zenith C36V23 36" TV
Where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
Sep 01, 2012 | Philips 32PFL3505D 32 in LCD TV
Press power on my philips 32pt6441/37 but power button flashes and no picture
Unfortunately, this is an aging tube type TV. I have repaired many of these when they were still in warranty. In your case you will be repairing the horizontal timing. You will replace a mosfet transistor (location 7404) an 8.2 ohm 2 watt resistor (location 3414) and a driver transformer (location 5402). If you feel you can repair this yourself, I suggest you order the horizontal timing kit with instructions. The number I give you may be obsolete. Don't worry, this number will get you a cross number to work with. Ask for part number 4835 310 57673 for TV chassis L04.1UAA. Thanks for asking and show all hands of support!
Jun 10, 2011 | Philips Televison & Video
32 LCD tv pic went out suddenly, sound works, fuse is good, signal is good to tv
You have bad capacitors in this unit. Replace capacitor (location) 2074 which is a 25 volt 2200Mf at 105 degrees. Change capacitor (location) 2081 which is a 35 volt 1200 Mf at 105 degrees. Change capacitor (location) 2066 which is a 16 volt 10Mf at 105 degrees. And to complete final repairs change out surface mount capacitors (locations) 2H08 and 2H09. The part numbers for these two identical surface mount caps is..223886975478. And one should consider changing the color crystal, also a surface mount. The number for this crystal is 823827736071. If unable to do this yourself, find a TV tech and show them this repair instruction. Good luck and show a few hands of support.
Dec 25, 2010 | Philips 32MF231D Television
Hi I accidentaly actiivate the child control on my tv and turned it off, I don't have the original remote any longer and I can not turn on my tv. Please help Mike
Concerning the problem...it is extremely likely that you have a corrupt EEPROM. A very common problem with this TV.The correct EEPROM (IC location IC 002) is dependent on which microprocessor (IC location IC001) and which stereo decoder (IC location IC 1001) are present on the board being repaired. Take this info to a TV tech and they will find the correct EEPROM to replace. Your TV will come back to life. If not, give me the numbers of ICs IC001 and IC1001. I will forward the correct EEPROM part #. Then the tech will repair your TV. Thanks for asking and show all hands of support!
Dec 01, 2010 | Philips Magnavox 27MS343S 27" TV
Philips tv 20pt1782 want service manual
hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
Jun 10, 2010 | Lexmark All-in-One Printer with PictBridge
Lines on the screen all times
You may try connecting other video source to the TV to ensure whether the issue is related to the TV. If the issue persists with all the video source then the issue may be related to hardware malfunctioning of the TV and service will be required. In this case, you may contact Sony Service Center to get the TV diagnosed serviced. If the TV is in warranty then service will be offered under warranty terms and conditions.
I would like to forward a link to a page where you can find a location to get your Sony TV repaired, the Sony repair cost, and to initiate the repair procedure provided you're located in the U.S.
http://www.eservice.sony.com
Jul 12, 2009 | Sony KP-65WS500 65" Rear Projection...
Service location for westinghouse lcd in brooklyn ?
Dont worry about the location, you dont need to take your TV to a repair center, just call westinghouse and let them know about your TV issue and they must send a tech over your place or replace it for no cost.
Jun 02, 2009 | Televison & Video
Philips 60P8341 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
