Acer laptop. unable to move mouse after touching a key. in safe mode able to determine keyboard driver "corrupt of missing". keyboard is a dritek inc. product. unable to find driver.
  • Prasad Chakraborty
    Prasad Chakraborty May 11, 2010
    Which OS U R currently using ? Was it preinstalled ?
    Problem Solver:
  • 19 Answers
Hi boulderbound!
What you need to do is to call Acer or go to their service center since they have the driver for your laptop. But the most fastest solution will be going to acer.com and download the necessary drivers for your laptop.
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Posted on Jul 27, 2008
My Lenovo mouse won't work. It connects and registers but won't move? Is there any help?
Try booting to safe mode and check if your mouse works inside safe mode.
Restart the computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight either safe mode or safe mode with networking. Hit enter.
Once you are inside safe mode, check if your mouse works. If it works, then you just need to update the mouse driver. You can use RadarSync to search and install the update into your computer. You better use Safe Mode with Networking because RadarSync needs the internet or even the manual updating process needs an internet connection.
I hope this helps!
David
Apr 12, 2013 | Lenovo Computers & Internet
Acer 5200 booting stuck
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
Jul 25, 2012 | Acer Aspire 5520-5156 Laptop
When i turn on laptop i get a reading ,"window failed because system registry file missing or corrupt.have no back up disk.how can i fix?
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
if you need more help with this poat a reply
hope this helps
Aug 26, 2011 | Compaq Computers & Internet
My acer 5100 aspire laptop's mouse and keyboard
I think you have disabled them.
There should be a key to enable mouse and keypad.
Jan 27, 2010 | Acer Aspire 3680 Laptop
Just bought Acer laptop (series 5517) and the keyboard appears to be locked. How do I unlock it??? Please help 9/27/09. Thanks!
DOES THE MOUSE WORK OK?
If not, re-boot and press the [F8] key to get into the "Safe Mode" screen. See if the keyboard works in Safe Mode.
If so, go tothe Control Panel and select "keyboard" and update the drivers.
If not, then re-boot and select the [F8} key again, but choose "Start computer in last known good configuration"
If it still doesn't work, but the mouse does, then the keyboard is disconnected or the connector is loose; open 'er up and connect it.
Sep 28, 2009 | Acer 91.63X07.001 Keyboard
The cursor will not move after I start system, what can I do?
check your key bord is working if it is working then you need touch pad drivers if you have other usb mouse you can check it with usb port of laptop if its work then you can solve this issue with touchpad drivers installation.
you can download your drivers from this link just select your odel from here.
http://us.acer.com/acer-v2/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Jul 27, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 6920: Broken Keyboard & Mouse Pad
open your laptop keys with nail cutter and see any problem is there
Apr 25, 2009 | Acer Aspire 1640Z Notebook
Keyboard/mouse pad problem - to the people who suggested taking out the battery
try to repair os installation it might be happening due to some driver conflicts . in safe mode only basic drivers like keyboard mouse etc will work other device drivers have no role in safe mode try it
Dec 04, 2007 | Acer Aspire 3000 Notebook
Keyboard control unit problem
either the keyboard/mouse (2 in 1 on laptops) drivers are invalid in which case you can go to http://support.acer.com and download the keyboard/mouse drivers and/or utility.
Let me know if this works for ya,
Have a great and safe Sunday !
Dec 02, 2007 | HP Compaq Business Notebook NX9010
Laptop freezes up
Try re installing both, while in safe mode go to my computer, right click>properties>hardware tab>device manager and go down the list to keyboard,click '+' and right click on keyboard and select uninstall. Re start laptop and see if it works ok. Do the same for the mouse, but look for the line mouse and other pointing devices and uninstal and restart. try also updating the drivers. http://support.acer-euro.com/drivers/notebook/as_3000_5000.html
Apr 18, 2007 | Acer Aspire 3003LCi Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
