FixYa.com
Tags:
Sharp AR-C160 Color Copier
Sharp AR-C160 printing
By Chandler - usenet poster
Client wants to use Sharp AR-C160 color copier as an AS/400 printer. Nothing
that I tried
works. Looks like we need a PTF to allow *IBMSNMPDRV as SYSSRVPGM.
Does anybody knows the needed PTF number?
Model 170 V4R3
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Melissa
Melissa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Paul,
thank you very much.
Great response.
You are the man!!
: Hi Roger,
: Here is the link to the IBM web page that lists the PTF's you need to
: load in order to activate the *IBMSNMPDRV program under V4R3.
[url=http://www-912.ibm.com/n_dir/nas4apar.nsf/c79815e083182fec862564c00079d117/0a4880d100c2552e862568ab006dce41?OpenDocument&Highlight=2,ibmsnmpdrv]http://www-912.ibm.com/n_dir/n as4apar.nsf/c79815e083182fec86 2564c0007...[/url]
: Good luck.
: Best Regards,
: /Paul
: Paul Tykodi
: E-mail: ptyk @yahoo.com
: > Thank you all for the clues.
: > Will try...
: > "Roger" <roger_k_07 @yahoo.com> wrote in message
: > : > : Client wants to use Sharp AR-C160 color copier as an AS/400 printer.
: >  Nothing
: > : that I tried
: > : works. Looks like we need a PTF to allow *IBMSNMPDRV as SYSSRVPGM.
: > : Does anybody knows the needed PTF number?
: > : Model 170 V4R3
: > : Thanks
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
Hi Roger
We've connected the AS400 to a number of photocopiers including,
albeit a mono model, the Sharp.
First try with the Sharp and we could get nothing to work. Then we
found that there were two ethernet ports. We left the network as it
was and put a jetdirect on the other port. It then worked straight out
of the box for plain text 132/198 and 120 portrait form overlays. We
had to redesign the landscape form overlays to match the text, but
once we did that it was all ok.  We use customised wscst objects for
our forms.
The simplest photocopier we've used is the Canon ir2200-3300 and the
worst is the Canon ir5000 which we have never got to work properly. We
get plain text out without any problems but form overlays just refuse
to work.
Sorry about the Canon ir5000 rant.
Cheers
Neil
Solution #3
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
Hi Roger,
Good luck.
Best Regards,
/Paul
Paul Tykodi
Solution #4
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
[url=http://www-912.ibm.com/s_dir/slkbase.nsf/$$Search?openform]http://www-912.ibm.com/s_dir/s lkbase.nsf/$$Search?openform[/url]
Search : Sharp
Look at LPR.
You have to create a remote outq.
crtoutq
Solution #5
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
Will try...
Nothing
: that I tried
: Model 170 V4R3
: Thanks
Solution #6
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
Hi all
In my earlier post, in this thread, I said that the Canon ir5000 was
the worst to connect to the AS400. Well the third Canon engineer has
now sorted it out.
All he did was to set the personality to "pcl", the default setting is
"automatic".
Our customer is now a very happy owner of a Canon ir5000.
Cheers
Neil
Can you Help with these Copiers problems?
Copiers
blotches
my Xerox Workcentre M15 has... Answer This...
Copiers
PANASONIC DP-1515P DRIVER
hello: i need the panasonic... Answer This...
Copiers
canon error
canon machina ir 5055n give... Answer This...
Copiers
copystar 2014 UF error code...
I have a copystar 2014 with a... Answer This...
Copiers
smudges on printout
Goodday Jay, Thanks for the... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
