Sound i have install window XP SP2, my sound doesn't come, when i try to play something it say "Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not be functioning properly." this that message come ups. i try everything on control Parnell. i am not sure what wrong with.
  • Anonymous Nov 07, 2008
    pi845glm is my mainboard my sound drives also same problem ple retified....sir\madem
  • Anonymous Dec 15, 2008
    I have the same proble - all other programs work fine (eg. VLC, Quicktime,...) Media Player just gives the same error message as for leenin_1987
  • 781 Answers
First off download (pcwizard) and install this program searches and finds the drivers needed for your computer go to the sound driver found note name and number write them down
EG cmedia 2341
go to search engine type in (cmedia 2341 drivers) put your own needed driver where I have cmedia etc and search for them download uninstall any sound driver installed reboot when rebooted install your sound drivers.
Sorry cannot be more specific as I do not know what your sound card is
Posted on Jul 27, 2008
    Problem Solver:
  • 19 Answers
Plz detail UR System Specs (At least Motherboard) as well as Sound Driver Name & Version.
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
When i play music or DVD on my windows media player there is no audio sound?
Open Control Panel - Sound and Audio devices - check the sound volume, move to high if required and Mute is not selected.
Next click on Sound tab and select a Windows and click on the play button, if the play button is greyed out then the audio driver is either not installed or not working. In this case install your model audio driver.
Jun 14, 2012 | Microsoft Windows XP Professional SP2
I'm trying to watch a video and a mesages appears that says "The selected file has an extension (.3PG) that it isn't identified by Winodws Media Player....". I can watch it but I...
Hi Welcome to FixYa!
1)Simply download and install K-Lite codec pack for Windows media Player. You could download it from this link: http://www.free-codecs.com/download/k_lite_codec_pack.htm
2)After downloading, just install it and restart the computer
3)You will now be able to watch or play files with different extensions using Windows Media Player.
Hope this would be a big help.
Enjoy!
Jun 27, 2011 | Computers & Internet
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
Windows XP SP2 reloaded but no sound while playing Winamp or windows media player
go to control panel... system... device manager and check that there isnt any ! in the audio devices. If you do find one then you need to install the drivers to your sound card.
May 25, 2009 | Compaq Computers & Internet
Cannot load ANY media files!
you may need windows xp sp2 because I had the same problem and I had to install windows xp sp2 because with sp3 which I had at the time I purchased the device it did not want to work. It is said in the manual that you need windows sp2 for it to work and be recognized.
Apr 03, 2009 | Philips Audio Players & Recorders
PC dosen't play sounds occasionally
heres a suggestion go back to xp service pack 2. service pack is very easy to use and more compatibility than sp3. right now my 10 pc's are all xp sp2 and they have no problems about the sound.hope that helps
CHARCOIS
Sep 14, 2008 | Computers & Internet
Sound Divice
an1978an
to ensure that sound driver is installed or not right click on "my computer" go to "properties" then click on "hardware" tab then click on "device manager" then chack any yellow question mark(?) or exclamation (!) mark is their or not if (?) marks show with ur audio device, mean audio driver not installed. installed it from mother board cd (which is provided by ur motherboard vander).
Jun 25, 2008 | ASUS P5PE-VM Motherboard
Sound driver problem packard bell moudle no.m5xxx
take a driver cd which will came with your system and try to install it agian after then you get it . it means that your sound driver is not installd properly
Jun 06, 2008 | Computers & Internet
Its not plug and playing Sandisk 240m 1g
Hi blackmajik, I just got a Sandisk m250. Windows wouldn't recognize it either until I updated my Windows Media Player to version 11. Now XP sees it just fine and the MP3 player syncs with WMP and accepts and plays music!
Jun 07, 2007 | SanDisk Sansa m240 MP3 Player
Computers & Internet Logo
550 people viewed this question
David Payne
David Payne
