Stockings stuck in washing machine
A pair of stockings became tangled under the rotator of the washing machine. How do you take the centre 'agitator' thingy out so we can untangle the tights?
thanks
Maddy
  • 177 Answers
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Posted on Jul 29, 2008
rickzilla
  • 706 Answers
SOURCE: drawstring tangled under agitator on an older GE washing machine.
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Posted on Sep 21, 2008
SOURCE: necklace stuck in washer
Hold the bottom part of the Agitator,(The part that you are talking about),Undo the very top part in an anti-clockwise direction and it will come right off.Use a wrench to remove the nut on the top of the agitator and then lift it right out,you may need to move it from right to left.You will now be able to remove the necklace.Replace the Agitator the reverse of removal.
DW
Posted on Oct 26, 2008
srsrs_1999
  • 9 Answers
SOURCE: Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Posted on Apr 30, 2009
  • 4345 Answers
SOURCE: I have a pair of shorts with a waist tie that is
WEll, hard to know with no brand specified, but usually the agitator can be removed by unscrewing a retainer bolt, typically under some cap at the top of the agitator itself.
Posted on Oct 05, 2009
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop ....in its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
Clothing stuck in washer machine
Is it stuck in the center agitator or the out tub?
Jul 04, 2008 | Washing Machines
What type of compression stockings treats Lipedema?
Compression stockings treats lipedema well.There are varieties of compression stocking materials for lipedema treatment.Circular knit/flat knit are of four way stretch and suitable for bigger limbs.Flat knit is expensive than a circular knit.Short stretch compression stocking are used to improve the venous and lymphatic function.Nighttime compression stockings are used to reduce the swelling.Visit Compression Socks Stockings Medical Grade Venocare for buying best quality compression stockings & elastic stockings in Ireland.
Nov 14, 2015 | Office Equipment & Supplies
Why does the agitator keep getting stuck and will only go one way
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 26, 2015 | Washing Machines
My sleve is stuck in the spinning deal of my washer, how do i get it out?
Remove the rinse dispenser from the top of the agitator (spinning deal). Unscrew the agitator cap located on top of the agitator which is only hand tightened. Once the plastic agitator cap is removed from the top of the agitator you should see a screw which you will need a socket or an adjustable wrench to remove the screw. The agitator can now be removed by lifting strait up to free the sleeve. My only concern is how the sleeve became lodged under the agitator unless the tub became unbalanced from a heavy load. The other possibility could be the support for the tub is broken and needs to be replaced.
Feb 15, 2011 | Admiral AW22 Top Load Washer
Fine garment caught under centralrotor has black mark on it , is this grease?
It is not grease. Under the agitator there will be a sticky buildup of detergent and dirt that has stuck to it. Overtime this buildup can become quite a lot. When your garment became caught up under the agitator, it was becoming stained with this buildup.
Jan 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Pants stuck under the agitator of my heavy duty kenmore washing machine. How do I get the agitator off?
unscrew the agitator from it's base, just hold the shaft with a pair of plyers and turn agitator.(you will have to take case off)
Aug 14, 2009 | Washing Machines
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Dec 25, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
231 people viewed this question
Top Washing Machines Experts
