Question about Coleman Heating & Cooling
MY UNIT IS CREATING ALOT OF CONDENSATION. I HAVE TRIED SO MANY WAYS TO FIX THE PROBLEM. THIS UNIT IS INSTALLED IN A MOBILE HOME. I HAVE OWN THE MOBILE HOME FOR 6 YEARS. HELP!!!!
  • 143 Answers
Air conditioners are SUPPOSED to make condensation. Lots of water means lots of good air conditioning :-)
Do not fix it. It is not broken.
Posted on Jul 27, 2008
GE Adora dishwasher model ddt575smf0es leaking from condensation
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Feb 25, 2014 | GE Adora GHDA654LBG Dishwasher
Water is coming out from under the unit
Water coming from a working a/c is normal (condensation). I believe the condensate drain line is clogged and needs cleaning. Follow proper maintenance by flushing the condensate drain line annually with two parts water and one part bleach.
Aug 24, 2013 | Intertherm Heating Cooling System 15kw...
The top of the unit has alot of condensation on it. so i am wondering if its freezing up inside. Have set point at 55% what can i do to fix the issue
A little condensation is not something to worry about. But, a lot can be caused by a dirty or clogged air intake filter. Which can also cause the cooling coils to freeze.
Turn the unit OFF & unplug it, before removing the filter for cleaning.
Also, maintain 12" to 18' of clear air space all around the unit.
If the unit is in an extremely moist or damp environment, 55% is not really a low setting. 35% would be more appropriate for this type of environment.
Hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | LG LHD459EL Dehumidifier
WKL 3000 is creating excessive condensation and icing on the bottom of the unit. It is about 13 years old.
There will always be condensation. The problem may be that the drain that carries the water off is partially plugged.
Sep 20, 2010 | Breezaire WKL 4000 Wine Cooler
My Ruud AC unit compresssor is creating a lot of condensation and home is not properly cooling.
check ur coils are they dirty how is your filter on hot days it will condensate alot however a unit is desighned to opperate for an average of around 87 degree day and may need the superheat adjusted. check and make sure the bigger line coming off that unit is very cold hold your hand over the outdoor fan is the heat off it very warm
Sep 11, 2010 | Ruud Central System Air Conditioner
We have a carrier heat pump/ac unit. Our ductwork in the attic has condensation all over it and it is dripping thru our newly installed insulation to the sheetrock on the second floor thereby staining,...
usually if there is a lot of condensation, then there is bare/uninstulated metal in the duct work. Now if the unit itself is condensating then putting a condensation pan under the unit with a drain should fix this problem. A far as the windows it will happen but shouldn't cause a mold problem. hope this helps Tim
Aug 22, 2010 | Carrier Heating & Cooling
This is our first summer to use our Goodman central air conditioning unit and we are having alot of condensation on our windows and doors. We need to know if our service tech installed a unit too small for...
Your issue may be just the opposite of what you suspect. If the unit is too small, it will run continuously, but may do a better job of de-humidifying the space because the A/C unit has more time to pull humidity out of the air.
Conversely, if the unit is too large for the application, it may run for only a brief time, make the space cold, but may not provide effective dehumidification, resulting in the problem you describe.
Condensation occurs when hot humid air condenses out on a cooler surface, which in this case may be your windows and doors.
Keep your eye on this issue as excessive condensation or moisture build up can result in mildew or mold.
Aug 20, 2010 | Goodman Heating & Cooling
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Too much condensation
I have never heard of "too much" condensation. The condensation is the the moisture that is being removed from the home. If the home is very humid and its common for alot of condesation to be removed from the coil. As long as the coil is not freezing up, you are good to go.
Jun 06, 2010 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
