Question about Philips Televison & Video
I have a 52 inch projection tv the red color is on the top and bottom of the screen how can you fix it
  • 10,421 Answers
You need to repair and or replace your Y sus. It is defective giving you a stranger colors on screen.
Regards, jay
Posted on Feb 21, 2011
SOURCE:
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Projection RCA P52940
sounds like it is most likely the convergence power supply board, if it were just one color It would most likely be the convergence board itself
May 27, 2008 | RCA P52940 52" Rear Projection Television
Rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
