Question about Lite On (SHW-1635S) DVD RW Dual Layer Burner
Dvd-rw drive malfunctioning
My dvd-rw drive cannot load or read any type of disk except a dvd disk. even a blank cd-r or dvd-r wont load, so i cant burn any disk also. even if there's a blank disk on the drive, while im trying to burn the disk using nero, the computer will prompt me to "insert a blank disk on the drive". i've tried updating the drive's driver, system restoring my system, updating the burning software i used (nero) but none of this solved the problem. please help!
  • djross121 Aug 18, 2008
    Having the exact same problem. I tried updating Firmware drivers, found a few versions (YSOZ being the latest) to no avail and I don't still have the CD that came with the internal burner. As far as checking the lens I'm not sure what all that entails and don't want to make matters worse .. is it a simple procedure? Also using NERO 7.10.1 and it reads DVDs but nothing else, as OP stated it just says 'insert disk' or 'spins' a CD without reading it. Would DLing a different burn software help or any other suggestions?
  • Anonymous Nov 09, 2008
    I have exactly the same prob with the same burner.....but mine will only read audio disks and not dvd's,pc roms or blank media!!
  • 163 Answers
This is a long shot but I had similar trouble with another brand of drive. With these symptoms I assumed the lens would not go to its "home position". If you know what you are doing you can remove the covers and check to make syure the lens moves freely. Good luck and let me know....MM85
Posted on Jul 27, 2008
    Problem Solver:
  • 19 Answers
Please Check :-
1) Whether U R using the Proper NERO. I want to mean, try installing the NERO which was provided with the DVD-RW+ Drive.
2) Check whether there is a Firmware Upgrade available for your DVD-RW+ Drive with the help of provided CD/DVD and a compatible Software.
I have a HT-DT-ST- RW/DVD GCC 4480B it will burn cd-r but it wont even read dvd-r I just want to burn dvd-r but it wont even read blank one
> CD-RW / DVD-ROM
Sorry, but this device is not a DVD-writer.
This device _should_ read (non-blank) DVD media.
If it does not, then the cheapest solution is to spend $40
to buy a new CD/DVD reader/writer.
Oct 26, 2010 | LG GCC 4480B CD-RW/DVD-ROM Burner
It can't read or burn any data on any empty disks (CD-Rom/DVD)! but it can read any other written disks like: programs , Movies , audio disks , data disks just when I put a blank or Empty disk it seems...
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Sep 25, 2009 | LG SecurDisc 8x External Double-Layer DVD...
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Won't recognize blank dvd
Chek wtat is written on front panel
If it DVD-RW it can record only DVD-R blank, if it + so only +R
or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
Also chek the speed for you DVD and disk you using.
If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
Good Luck
Jan 10, 2009 | Microsoft Windows XP Professional With...
DVD-RW not recognising blank disk
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
My dvd burneer wont reconise dvd and dvd_rw discs
Check the blank disks in another computer if you can in case they are damaged and causing a fatal error when your computer tries to read them, and the reboot.
Are you sure it's SCSI and not SATA as scsi isn't very common these days especially on desktop type PC's? Where are you looking to see if the driver is correct?
If the drive is displaying and can be accessed from your operating system then it should be working fine.
Jan 04, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Samsung DVD Rom drive SD 612B
Its a dvd-rom drive. READ ONLY MEMORY.
That drive will not burn a dvd...it has to say dvd-r/dvd-rw.
or be referred to as a super drive.
Hope this helps.
Aug 21, 2006 | Samsung (SD-612) Internal DVD Drive
Lite On (SHW-1635S) DVD RW Dual Layer Burner Logo
281 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
