Question about Proscan PS61670 61" Rear Projection Television
Hi there I've noticed youve been really helpful so...
Hi there, my rear projection tv has all the colors misaligned and has a )( effect, I have tried adjusting the focusing on the projectors but it doesnt seem to change the actual position of the color and i cannot change the pinchusion effect within the service menu, i have found my digital convergence IC (i only have one, i have noticed lots of people saying that their's 2? and mine doesnt have a heatsinc either) its an STV2040T
so if i replace this part and then adjust the projectors for alignment the )( effect and colors will be fixed?
    Champion:
  • 205 Answers
The )( is indicating your loosing High voltage required to pull the raster across the screen. This can be tweaked but a short lived solution. I suggest it may be a good time to start shopping.
Posted on Jul 07, 2009
My hd1080 color is multi and my picture is blurred
Unless the unit was moved and RGB section misaligned, the other condition could be a defective controller circuit board.
If it is old, heat builds up over time and the components start to breakdown. Remove the back of the TV and see if there is a collection of dust and debris that could effect the operation of the TV.
May 10, 2014 | Mitsubishi WS-65413 65" Rear Projection...
I have a Hitachi F5F110. The red/pink is way out of balance on this TV. I've done everything I can do to try and fix it, including the magic focus built in on the computer and I've also turned...
51F510 SHOULD use two STK392-150 CONVERGENCE integrated circuits. Too much to explain here but I am available on the site as a pay question attention: SD TECH.
sd tech
Sep 19, 2011 | Hitachi 51F510 51" Rear Projection...
Colors are separated, double vision in lower right corner.
Oh, yea - another misaligned projection TV. All rear projection TV's seem to eventually get this disease.
Fix: perform a "convergence," which will converge all 3 color projectors to the same point.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Dec 11, 2010 | Sony KP-53XBR200 53" Rear Projection...
The 3 colors are not ligned up and the picture is out of focus. We tried the flash focus and that did not work. we tried the convergence but are unsure on how to use it.
Colors misaligned in rear projection tv due to failure of convergence output ICs and replacement of bad ICs will solve your problem, it needs soldering work in tv circuit board with proper tools, if you are handy with electronics stuff repair ad can replace parts in circuit board then let me know to provide you more info OR contact local tv repair shop to get tv fix.
Thanks.
Oct 31, 2010 | Sony KP-51WS500 51" Rear Projection...
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence???
If the sides are bowing in like this )( that is called a pin chusion problem, normally you have a problem in your vertical circuit, a tv tech would be able to narrow it down but a good thing to do if is scope your vertical pulse from the vertical IC to narrow the problem down
Aug 18, 2008 | Panasonic PT-47WX52 47" Rear Projection...
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
