Question about GE 29472 Corded Phone
RING I DO NOT GET IN COMMING RING
  • navroz963 Jul 27, 2008
    Thanks can you sent me pdf file for same phone?
  • Anonymous Apr 13, 2009
    cannot recieve incoming calls
  • 58 Answers
Ensure the ringer switch is in the on position.
Posted on Jul 27, 2008
Mitsubishi rosa bus
this an indication of excessive blow by around the pistons normally ring failure.. check the oil level as well. Have a compression test done on the engine.
Jun 02, 2013 | Cars & Trucks
1999 toyota Tocoma 2 wheel drive ABS light comming on and the brakes drage and ABS activates at light braking
Hi. Usually if the abs activates under normal braking, its usually one of the wheel sensors is malfunctioning .
Also i have seen the segmented ring which rotates with the wheel, come loose on its shaft (rust gets to them and the ring cracks so is then loose on its shaft) Or the segmented ring (toothed ring) has got dirt or rust between some teeth therefore giving wrong signal to the ABS system
Ihope tis will be of some help to you
John (south Wales UK)
Apr 15, 2011 | Toyota Tacoma Cars & Trucks
Light smoke is comming out of the tailpipe
your piston ring may worn.... need to overhaul.
Nov 20, 2010 | 2000 Audi A4
Hi i have a oil leek comming from the oil filter houseing on a bmw 97 e36 318i how can i fix this..... regards cameron
replace the o-ring that keeps the oil from leaking from the housing to the engine block. A lot of work.
Nov 16, 2010 | BMW 318 Cars & Trucks
In comming and out going problem
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Feb 19, 2010 | HP OfficeJet 4255 All-In-One InkJet...
I do have a honda EXHA2425 Pressure washer and my pump leaks water .How can i glue it plz
if its comming from between two metal parts, you need to dissassemble them to see if it takes a gasket or o-ring. o-ring is most likely, take it out and to a hadware store to find a new one same size, glue will not work because of the pressure involved.........
Jun 29, 2009 | Honda Garden
Assign different ring tones for email or text mess.
You can not do that as far as I am concerned. It's all the same sound for any type of message.
Mar 04, 2009 | LG Vu CU920 Cellular Phone
Oil on top of lower intake manifold
Its a common problem, but it has to be adressed before your engine is done. That oil is comming out wear the distributor wonce was. The plentem, or what you call upper intake will have to come back off, in order to get the plug out to chg. the rubber O- ring on the plugWhen you get it out it will look like half a distributor with the gear on the end and the O- ring towards the top. Its located right under the throuttle on left side of engine where the trans and block meat. There might be enought room to get it out without pulling the intake i'am not sure. But thats where the oil is comming from manny an engine has tied up because of that leak.
Feb 08, 2009 | 1995 Buick LeSabre
GE 29472 Corded Phone Logo
21 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
