Question about Refrigerators
My westinghouse 312 keeps leaking water - Refrigerators
    Problem Solver:
  • 10 Answers
Need more information...
Where is it leaking?  from the back, inside, underneath?  can you see the leak?  if so, give some details
Posted on Jul 27, 2008
Leaking water
if this Is a Westinghouse this is a fare common occurrence , its coming from the auto defrost system as the evap fan down in the pan isn't working so all the water that should be evaporated isn't and it keeps adding to it till pan overflows , a quick ck with a good flashlight will allow you to see full pan , if water is coming from lower door , then your auto defrost drain hole is frozen up , unfortunately only way to access it is to mt fridge and unplug it for several days and allow it to thaw out then chase hole out with a pipe cleaner and replug it in , keep food away from this hole and you shouldn't have anymore problems
Mar 29, 2016 | Refrigerators
Westinghouse SB921WG dishwasher leaking even when not in use.
I would start by checking the hoses to the machine as well as the fitting connections.
Aug 27, 2015 | Westinghouse Dishwashers
I have a westinghouse side by side frig about 10 years old. Model number RS695V Serial number 34700050.The problem is water is leaking out of bottom of freezer door. I believe it is caused by a clogged...
The hose that goes to the water dispenser most likely has a crack in it somewhere inside the door. Usually the heat from the light in the door deteroriates the hose and lets water leak inside the door every time the dispenser is used.
Feb 19, 2015 | Westinghouse Refrigerators
Westinghouse dishwasher error code i30
Not familiar with this particular model but the indication is for water in the very bottom of your unit. Either due to a leak or a faulty switch. A quick leak check is to tip your unit to the side and see if water dribbles out of the bottom. Side needs to come off and either find and fix the leak or replace the switch itself. If its just a leak and you tip the water out it will actually work till the leak fills up again.
Jul 08, 2013 | Westinghouse Dishwashers
We bought a Westinghouse fridge on Saturday we hooked up the water as per instructions the water flows to the conection on the fridge but nothing comes out of the water dispenser.
Is it brand new if so keep pressing the lever, I have had it take minutes before the water arrives. There is a long stretch of coiled tubbing inside that the water has to pass through.
May 22, 2011 | Westinghouse Refrigerators
Leaking westinghouse 9.5kg washing machine
a hose has partially come off or a cut in the hose
Sep 06, 2009 | Westinghouse Washing Machines
Leak - water not evapourating
check your doors may be not clossing (ajar) or check control to high
Apr 02, 2009 | Westinghouse Refrigerators
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
