Question about Nikon F5 35mm SLR Camera
Nikon F5 Embarrassing I know, how do I load film into my camera? got same problem when loadind a film roll no easy access
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
NikonF5
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 27, 2008
I thought I loaded the film in a Nikon F100. The Camera showed the film was moving 1-24 I got to 24 the film re-winded I took it to get developed and The film was clear I just need to know how the load...
Since you managed to close the back of the camera and shoot, you've placed the actual canister into the camera correctly.
What happened is there are a series of pegs on the left side of the camera, or sometimes just a red indication line, that the film must be placed onto. If you don't lay the film onto this, the camera won't pull the film out of the canister when you shoot, but it will rewind it back into the canister correctly when it thinks you are out of shots. This will result in a blank roll of film.
Feb 16, 2011 | Nikon F100 with 28-80 and 70-300 lens 35mm...
I have an old Nikon Lite Touch Zoom 100 AF camera and I am having trouble loading the film. Can you use Kodak Advantix APS film in this camera or should I be using manual loading film instead?
This camera uses 35mm film, not APS film. 35mm is a larger format, giving MUCH better results, at the expense of having to manually pull the leader across to the take-up spool each time you load a roll.
Dec 29, 2010 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
N55 Shutter Problem
If the shutter blades get bent they are hard to straighten out. Better to find a local repairman or you could do more damage to the shutter. Sorry to be the bearer of bad news.
Jun 11, 2017 | Nikon N55 35mm Film Camera
Nikon F5
You can download the manual from the link below: ftp://ftp.nikon-euro.com/Manuals/SDMYVNQN/F5_En_014.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 26, 2007 | Nikon F5 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Nikon F5 35mm SLR Camera Logo
263 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
