Question about Acer Computers & Internet
When I hook up my acer monitor it says no imput
Assign IRQ to VGA: Enable
PnP O/S Installed: Enable
VGA Pallet Snooping: Disable
PCI Bursting: Disable PCI Latency Timer: 128 Peer Concurrency
Posted on Jul 29, 2008
    Novelist:
    Scholar:
  • 141 Answers
Before making sure you have all the plugs & connections in the right place, look at all the pins on the end of the monitor plug that plugs into your on board/video card making sure none are bent or missing. If not, then try swaping with a known working monitor. If good monitor doesn't work either theres a good chance you may need to either add or replace video card.
If none of these options work you can let me know and I'll try to suggest something else.
Posted on Jul 27, 2008
Can i hook up my xbox to a Acer V223W EJbd monitor
Yes, you can get a DVI or AVG connector and use those.
Mar 09, 2013 | Acer 22" V223W EJbd Widescreen LCD...
Can I hook up a monitor to a Harbinger HA120 Portable PA System
Yes you can,you will need 2 run ,1\4 in 2 jack 1\4 in imput too the mic\line imput your chaing your signal so you will need too preset vol levels on the 120 too your desired max peak out put buy first putting you output slide too max on your mixer (running a signal from a cd player or other divice into mixer)then turn vol up 2 disered max loudness you want to run sound at then lower the vol using out put from main power slide on your mixer. Its called chaining your componets .better way of hooking up a band on a small system.ywc Rev bob dj 25yrs exp
Sep 06, 2012 | Harbinger HA120 Portable PA System
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
Acer T230 H monitor Hdmi ConnectionProblem
I don't think your doing nothing wrong, but I may be wrong. I would just stick with the other connections. HOpe this helps!?
Please rate solution - Thanks.
May 14, 2010 | Acer T230H 23 inch LCD Monitor
The screen says imput not supported but I can hear the startup sc
You need to set your PC video resolutiotn to the native resolution of this monitor, 1440 x 900 @60Hz. You get the message because the old setting for your old monitor (crt?) is too high for your Acer. You may have to hook up your monitor and set up the new resolution. Or you boot up in safe mode, set the resolution to 640 x 480, reboot into regular mode, reset the resolution again to be 1440 x 900 @60Hz
Apr 04, 2010 | Acer V193w LCD Monitor
GTA IV problems
try in game option a small resolution
Mar 07, 2010 | Acer AL1716 F Monitor
"Imput not supported"
What resouluton is your video card set at? check the specs on the monitor and set the proper resoulution and or refresh rate good luck
Apr 22, 2009 | Computers & Internet
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Computers & Internet Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
