Question about Sanyo DS31590 31" TV
Very dark picture on TV
My picture on my TV has become very dark, & very red, greens& blues are very dark too. On interior shots, the faces of the people can't be seen. Vey dark reddish complexions.
  • 218 Answers
Try restoring all factory settings. On your remote, press the reset button twice. If that doesn't correct it, then you'll probably need a repair technician. For more info, consult your owners manual, which is also available at
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fe26abca0a54ad7cbe4ba91bb243a7c2&q=Sanyo+DS31590
Posted on Jul 27, 2008
1995 27" zenith tv picture dark with red glare won't adjust
THE TUBE IS CARBONIZED -IF YOU HAVE A TECHNICAL KNOWS
PUT 9V CA or CC IN FILAMENT AND A LAMP MAX 15WATTS IN SERIE WITH ANODE AND RED GREEN BLUE CATHODE (ONE AT TIME) -OFF FILAMENT AND YOULL SEE SPARKS INSIDE THE TUBE WHEN DESCABONIZE. REPEAT AT LEAST 3 TIMES
Sep 25, 2013 | Zenith B27A11Z 27" TV
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
Too much green dont have orginal remote. Is there
your tv needs repair one of the transistors on the neck board is bad..the neck board is connected to the picture tube end inside the tv..but be care full as it stores very high voltage.if you are not a tech have a tech look at it.
Jul 11, 2010 | Zenith Televison & Video
My picture has far too much red in it. Where do I
there should be 5 or 6 preset on the crt(tube) base 3 of them should adjust red /green blue in the white aera and the other 3 adjust re/ green /blue in the dark aera make these adjustment with the colour turned off.
Sad to say that this is most likley a low crt the blue gun as gone low.
Mar 06, 2010 | Orion1934 19" TV
Problem with picture color
Magnetized The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 26, 2009 | RCA F27TF720 27" TV
Toshiba 35A44 Screen dark despite max brightness setting some OK
could be the sharpness, color, brightness, or a combination of them
May 05, 2009 | Toshiba 35A44 35" TV
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Sanyo ds31590 picture's very dark and red
sounds to me that your picture tube needs rejuvenated.
You will need to get it done by a tech.
mechanical doesn't mean a thing when it comes to electronics.
Mechanics when working on electronics, end up costing more damage when you end up taking it to a tech.
Oct 23, 2007 | Sanyo DS31590 31" TV
Dark and red picture
First you can up the screen voltage, by finding the HV transformer. It has Screen and Focus control on it this it the Transformer that is in back of set and has an anode lead going to Picture tube. Come up on the screen control slowly and if the picture brightens with vertical lines then it's too high, The red problem is a small transistor that maybe located on the CRT board. It's probably shorted. There are about 3, each going to the different colors Red, Blue, Green.
Sep 13, 2007 | RCA F35317 35" TV
The picture is only producing the basic colours red green and blue
Can you post a picture of the Tv with the issue stated?
Feb 28, 2007 | JVC AV-24F703 24" TV
Sanyo DS31590 31" TV Logo
276 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
