Question about Sony STR-DA2100ES Receiver
Can I connect a power amp to this unit?
How do I connect a power amp to my STR-DA-2100ES? what outputs do I use and what input? I have am ARCAM P90 and a NAD t 572 CD/DVD player which I intend to use for music only.
thanks in advance
    Problem Solver:
  • 9 Answers
If your 2100ES has a selectable INPUT AND OUTPUT and if you're intending to send all signal to the power amp, i.e. not bi-wiring or using the 2100ES to run mid-range or treble then you simply send Left & Right audio (White & Red cable) from a 2100ES output, probably AUX OUT ( it doesn't really matter apart from Phono on some units) straight to the power amp on AUX IN.
We should be just dealing with audio here, so connect the NAD audio output to CD or DVD IN. Select CD or DVD IN on 2100ES input switch and switch output to AUX OUT (whatever you decided goes to the power amp) on the 2100ES. Turn power amp to AUX IN and it will now get an audio signal from the 2100ES for amplification.
Speakers connect to the power amp as a normal amp, so pos and neg etc. The 2100ES now only acts as a signal feed, the power amp does all the work.
So, summary - switch on the NAD, press play - video goes separately and audio goes to the 2100ES. Turn 2100ES to INPUT for NAD. Turn 2100ES to OUTPUT allocated for power amp. Turn INPUT on power amp to allocation for 2100ES.
Turn it up!
Posted on Jul 12, 2009
  • roedene Jul 12, 2009
    problem with my first...
    It will only amp left and right front, 2100ES should still deal with others in 7.1 range. It might be unbalanced, i.e too much front.
    I'd quite enjoy it, and would want more punch anyway, but other range might be diluted or drowned out.
Protect problem
Cold solder joints can cause this problem
Jul 20, 2017 | Sony STR-DB780 Receiver
Sony STR-DN1010 with RCA output jack to Peavey PV-215 speaker input jack
is this a line level out put on the Sony? all the amp outputs on this unit use Banana Plugs, you will need an amp some where if it is. This speaker is not powered.
Jul 25, 2013 | Peavey PV-215 Dual 15 2-Way Speaker...
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
I would like to know how to properly connect my roland kc350 to my yamaha p90 for execellent stereo sound. seems like the sound is not quite perfect when i plug into left/right inputs on amp from...
Correct connections to connect your keyboard to your roland amp, and then the amp to the PA would be:
Two mono 1/4" jack (regular guitar leads) leads to connect the sockets labeld L and R on your P90 into channel 2 L and R on your amp. (channel 2 is better as you cannot overload it like you could on channel one, which has enough gain for microphone)
Then, using either the jack or XLR (XLR would be better if your PA mixer can accept them) sockets on your amp labeled LINE OUT, hook up your roland amp to your PA. Make sure to use the correct line outs on the top panel, NOT the stereo link or Sub outs on the back.
May 04, 2011 | Audio Players & Recorders
STR-DE835 dead audio. I have a high powered cb radio in my truck will over come amplified stereos. I keyed up the cb not knowing that the tuner was on and now I have no audio. The unit powers up and...
I have seen the higher power cb's fry the fm front end sectioon of the tuner section....did you try to put it on an aux input?....the click you hear is the amp protection relay and it sounds like it is working ok....if it were the output side of the power amp, then the relay wouldn't click after power up...it is probably the front end...this is the entire fm tuning section usually contained inside a metal box near where the antenna comes in
Feb 02, 2011 | Sony STR-DE835 Receiver
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
Arcam CD73 fault
Hi there. I would check the power supply rails, you have probably lost a volatge about the Audio line output /DA stages. Check voltage reg packs, they fail alot. I have repaired a few of these over the years, hit me back if you need to go further.
regards
Graeme
Mar 27, 2008 | Audio Players & Recorders
Tv trouble shooting
whenever any fusible resistance fails means there is a short ckt in tv. failure is mainly due to main filter cap or rectifire diode os switching ckt failure(here as you cleared str.) remember while servicing power supply isolate hor. section for safety purpose.& connect it only after power supply output is ok &after checking parts in hor. ouyput section. if this seems to be ok then go for hor.output ckt failure like hor output,flyback transformer & cap& diodes connected with it.
Oct 02, 2007 | Televison & Video
Sony STR-DA2100ES Receiver Logo
177 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
