Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Troubleshooting Purchased this item NEW, ran 4 hrs,shut off and went into self diagnosing mode,has 8 red flashes, wont start up, need help please . My Model is KDL-52W4000
  • Anonymous Aug 28, 2008
    I have the same issue for Sony XBR4. Let me know if you find any solution.
  • 320 Answers
8 flashes indicates a main processing IC on the video process board has failed You will need to have the BU board replaced.
Posted on Oct 19, 2008
1996 acura TL wont start.
possible you have to reset antitheft mode ,is there a red light flashing when you turn key to on possion not starting it ? some will reset by putting key in drivers door and turning it open close 3 times look for lights to flash then try to start.
Sep 12, 2012 | 1996 Acura TL Series
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Tv wont turn on, red timer/delay light flashes starts to come on then shuts off again
hi,
watch how many times ur standby indicator flashes. flashing of led is its self diagnosing system. if u tell me how many times its flashes, then i can tell u where is the problem
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
Sony lcd projection tv in self diagnosis mode. 4 red flashes
This is a fan error take the back off the set and see if the fan is turning.
Sep 13, 2009 | Televison & Video
Printer flashes "Clean Unable 46 - refer to troubleshooting and routine maintenance in User's Guide". I went to the user's guide and did all the maintenance/cleaning that was reccommended. Nothing cha
Try resetting the purge counter:
1) Enter machine maintenance mode (on MFC240C all fourphoto/copy/fax/scan lights flash in maintenance mode). Care is neededin maintenance mode, otherwise critical settings may be inadvertentlycorrupted.
FAX models with numerical keypads:Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if youfail to complete the correct key sequence within two seconds, press theStop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys.Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenancemode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the loginformation list to reach the purge counter. The purge counter is the25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jun 02, 2009 | Brother MFC-3360C All-In-One InkJet...
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Mitsubishi HC1500 DLP Projector
This sounds like an overheat issue and requires return under warrantee.
Oct 06, 2007 | Mitsubishi ColorView XL30U Multimedia...
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
