Question about Cyberhome CH-LDV 700B Portable DVD Player
Power supply plug in worn need to chg
Power supply socket worn , can I get parts & diagram to see how to chg. it thanks
  • Anonymous Jul 30, 2008
    I also can not locate a power cord to buy for my CH-LDV 700B.
  • Cybex107 Oct 06, 2008
    My dog chewed thru the cable, I am looking for buy a replacement power supply, where can i find 1
    Champion:
  • 303 Answers
I have an old JVC ALE 1BK turntable. Do I need a pre amp? It was part of a stacker system. Also, I need to know if there is a specific ac\dc 12 v adaptor I need to get or will a bog standard one do ( power...
You will need a pre-amp if the amplifier you are using doesn't have a phono input socket. Any balanced 12v power supply will work - but you need to get one with correct plug for the turntable socket (or one which comes with a range of plugs.)
Jan 28, 2015 | JVC Computers & Internet
Yamaha v star wiring diagram
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha Star 1100 wiring diagram Google Search
Electronics Star 1100 Wiki Knowledge Base
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Apr 13, 2014 | 2005 Yamaha V Star 1100 Classic
2001 Kawasaki VN 800 Vulcan Drifter wiring diagram
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2001 Kawasaki VN 800 Vulcan Drifter wiring diagram Google Search
Kawasaki Motorcycle Wiring Diagrams
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Jul 08, 2017 | 2001 kawasaki VN 800 Vulcan Drifter
Wiring diagram
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
wr426 Wiring diagram Google Search
Wiring Diagram
YAMAHA WR426F Owner Service Manual
YAMAHA WR450F Owner Manual
Feb 13, 2014 | Yamaha WR 426 F Motorcycles
Sharp LC-H1300 power supply wiring diagram? got the tv with only the socket installed and the wires were cleanly cut. thanks.
Check the site linked here. Hopes that it will help you.
. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 04, 2014 | Sharp Televison & Video
2005 1700 warrior has no power to headlight or dimmer fuse good, new light
Hi, Warren if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
Headlight Won Light
Headlight stopped working
Yamaha XV1700PCRC Service Manual
Yamaha XV1700PCR Road Star Warrior Owner Manual
Jan 31, 2013 | 2002 Yamaha Road Star Warrior
Honda NF 100 Wave headlight not working
3. Worn, chafed, or broken wires in the light circuit.
5. Faulty hi/low beam switch.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Headlight problem in my honda 125cc bike
Headlight problem
https://tefernibo.files.wordpress.com/2015/07/honda-wave-100-service-manual.pdf
Honda Wave 100 NF100 Parts Catalogue pdf
Honda Wave 110i User Manual
Apr 05, 2012 | Honda NF 100 Wave Motorcycles
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a...
good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Apr 07, 2011 | Microwave Ovens
I don't have the manual for 277498-011
As for the Power Supply 99% sure it is an ATX which as long as you get the same Watt as the existing you will be okay. Make sure you look at your existing connectors to see if you have a 24 pin or 20pin motherboard and 4 pin or 8 pin additional power plug (black and yellow wires) and the new power supply has matching connectors....older ATX supplies have only 20 pins, but there are converters from 20 to 24 pin available.
Watch for the new power supplies and your drive connectors as some of the new power supplies have limited ATA plugs...if you have a lot of ATA devices you might need SATA power convertor plugs or ATA splitters to get all you ATA devices up.
Sep 11, 2009 | Compaq ( 277498-001) Motherboard
Dvd works great ,need to replace power socket ear phone socket
sorry my mistake, I was trying to find afree service diagram to help me change a worn power socket in grandson`s cyberhome portable dvd model ch-ldv 700b. Thanks
Jul 15, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
Cyberhome CH-LDV 700B Portable DVD Player Logo
201 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
