posted by jbyrd_3 on Jul 27, 2008
washing machine full of water spins but will not drain any suggestions
Solution #1
posted on Jul 27, 2008
Check drain hoses and pump for blockage. These are usually located under the tub so you will have to remove the covers. If not then the pump may be bad. MM85
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer
GE 3.5 Cu. Ft. Capacity Commercial Washer with Stainless Steel Basket, WNRD2050DWC
GE Appliances 3.2 cu. ft. Super Plus Capacity Washer
GE WWSE6260B Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch Classixx WVF 2402 Front Load All-in-One Washer / Dryer
Can you Help with these Washing Machines problems?
Repair Service
Find Washing Machine Repairman Near You:
