Question about Sharper Image Ionic Breeze 3.0 Air Purifier
SI397 Ionic Breeze 3.0
Brand new. Won't turn on-no lights, sound, nuttin!
    Brigadier General:
  • 6,966 Answers
Hi again,
For some reason, I think the system has hanged. My windows shows that you are still typing a message for more than an hour. Our apologies for any inconvenience.
Anyway to your concern, if you were able to take it apart, checking would require that you use a continuity tester set at X 1. You need to check from the plugs back to where it went inside. The idea is to check the wires inside the cord. The meter/needle moving towards the extreme right indicates good continuity. Thereafter follow the two wires where they went inside. It maybe a circuit board, it maybe a fuse, or even the switch. The switch and fuse should also be checked for continuity.
Since your problem is a completely dead unit, then chances are the problem is among those listed above to be checked. If by chance none proved to be defective, am afraid that you have to seek the services of a qualified professional as all other tests requires a fair knowledge of electronics/electrical circuitry and components and possibly parts replacement.
Again our apologies.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 27, 2008
My ionic breeze GP air purifier will not turn on. I turned it off to clean the blades and when I reinserted and tried to turn it on nothing happens.
Hi.
The filter will probably needs replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. New model use a completely different technology. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 13, 2010 | Sharper Image Air Purifiers
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Regards.
Ginko.
Mar 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Dec 19, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze - Cleaning Overdue light stays on even after unit has been cleaned
Hi.
The filter is damaged and may need replacement.
Regards.
Ginko.
Nov 18, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze stopped working won't turn on was very dusty, cleaned it wont light up
Hi.
When this happens, usually the filter must be replaced.
Regards.
Ginko.
Oct 23, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze GP S1830 just seems bead, no lights
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 11, 2009 | Sharper Image Hybrid GP (SI724) Air...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
100 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
