Question about Toshiba 50HX81 50" Rear Projection Television
Repairman for your TV yet?
You mentioned that you were having the same problem as we are with our Toshiba TV having a scrambles picture until it warms up. I was just wondering if you had a repairman out to look at it yet? We're planning to sell the TV in a yard sell in a couple of weeks and would like to be able to tell any potential buyers if the problem can be fixed and appx. cost.
  • 4 Answers
Actually I found quite a bit of info regarding the problem and confirming that it has to be the caps on the hyperboard as hdtvman was mentionning.
I've bought the caps for less then $3, and will give a try at replacing them probably next weekend. I have nothing to loose as it's getting worse day by day now. If I screw up I can alway order the hyperboard from PTS...
Posted on Jul 27, 2008
My TV pictures scrambles after warming up
Check and replace all the electrolytic capacitors.
Aug 28, 2012 | Televison & Video
It is a toshiba 57h81 and i would like location of vidio board
Check this site for the solution
Read down basically it a heat
and esr problem with capacitors
also check here
for the tools etc you
may need if you are going
to do this yourself
Dec 08, 2007 | Mitsubishi WS-55809 55" Rear Projection...
I have a toshiba 56Hm 195 only half has picture
a PROBLEM likely to be either in the optical light engine or a separate digital board in the set---engine is more likely and a very expensive part not to mention labor.
Mar 18, 2012 | Toshiba 56HM195 56" Projection HDTV
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Picture is scrambled until it warms up. Can play DVD without any issues, but all other video inputs are scrambled for 30 - 40 minutes.
unit has a bad hyper module,NLA thru toshiba.try contacting tristate module or pts to see if they still rebuild part-23786198,MVPU13,PD0264A
you mite have to search to web a bit to find one if they dont rebuild them anymore.
Sep 29, 2009 | Toshiba 42H81 42" Rear Projection...
- Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
Mar 13, 2009 | Toshiba Televison & Video
Scrambled picture
I have the same problem here as well, except that it has been happening so long that now it doesn't get completely clear. The picture was great at one time :-(
Jul 07, 2008 | Toshiba 50H81 50" Rear Projection...
TV picture scrambled and getting worse
This can be a fault in the tuner, IF, or primary part of the video processing. With age and use some of the parts, and especialy capacitors, in these sets can become thermo sensitive and unstable.
To service these types of faults can be very time consuming. On top of this would be the cost of the parts.
Considering the age and type of set that you have, I would suggest that it is time to be looking for a new set.
Jerry G.
Apr 21, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba Projection Television Problems
we are facing server problems please reply to me at
don't worry i have found your part..
Apr 11, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
