If you have a po725 fault code"engine speed signal" this would be an indication of a bad crankshaft sensor.the good news is it's only 50.00.the bad news is it is a pain the *** to replace!it is located on the firewall side of engine block above oilpan rail by trans bell housing.i replace them from the top reaching down but its all feel...cant see anything.if its the vehicle speed sensor in the trans your after this is about 150.00 and is located in final drive section of trans right above the drivers side inner c/v joint.much easier to replace.hope this helped...let me know.
SOURCE: crankshaft poistion sensor location for
Its right next to the passenger side drive shaft, where it goes into the transmission. Right above the drive shaft. It s black with green slider inside of the connector and it has 3 wires coming out of it.
SOURCE: Location of oil filter on Nissan Altima 2005
The oil filter is located behind the right (passenger) inner fender cover. It is right next to the crankshaft pulley at the bottom of the front of the engine facing toward the right front wheel. I do not have a picture at this time.
Hope this is helpful!
Nissan Scope Technician- 10+ years experience in Nissan dealership.
SOURCE: IAT Sensor Location on a 2005 Nissan Altima
It is small and round (2 wire connector) and located either in the flexiable air intake hose to the engine or in the engine air filter housing.
SOURCE: Where is the Speed Sensor located on a 2005 Nissan Altima?
An engine speed sensor is mounted on the vehicle’s
crankshaft and is usually where the speedometer gets its data, whereas
wheel speed sensors are located individually at each wheel or axle generating
a signal that changes with wheel speed.
It is important that these two speed sensors are always in good working
condition to provide accurate data. If one of them gives the wrong signal,
control functions of the engine ECU and ABS ECU will be largely compromised.
So to have a long-lasting speed sensor, cleaning it every now and then
is necessary. Simply wipe off the grime it has accumulated with a towel.
Or it’s okay to carefully blow-dry it with compressed air. Anyway,
it does not need to be hospital-clean, it just needs to be free from major
debris and metal media.
If this didn't do it for you call autozone and they can pull up pictures of it for you and it will show the location to the exact positioning.
Hope This Helps
SOURCE: location of speed sensor in alitma 2005 2.5
Boritz2: there are several speed sensors on this vehicle, so I will give you the locations of all of them due to the fact that I don't know which one you are seeking.
There are speed sensors located at each wheel to work with the ABS unit.
On the trans-axle, on the driver's side near the top of the transmission.
I hope this has been helpful to you.
Is there a reason you are looking for the speed sensor?
