JVC KD-S550 CD Player Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My radio does not keep stations set after I turn off my car then restart it. I have reprogram in order to listen to a station
Anonymous
Level 3:
President:
  • Master 676 Answers
  • Posted on Feb 21, 2011
Anonymous
Master
Level 3:
President:
Answers
676
Questions
Helped
287496
Points
2168
Hello my name is Israel and I will help you. You will need to get to the back of the radio and check the yellow wire. Be sure the fuse if good (if it has one on this wire). Next, be sure that it is connected to a constant +12 volts (power even when vehicle is off). Good Luck
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Preseting radio stations so i don't have to use the tuning dial everytime
Most radios let you set them like this - select bandwidth FM/AM then tune to a favourite station, find the row of numbered buttons under digital display (usually 1 - 5) then press and hold button 1 for a few seconds, the station will be set to button 1, so to speak. Repeat tuning to another station then press button 2, etc...some radios have up to 15 slots per band. How many stations do you listen to....
To recall station 1, press button 1 ..button 2.......... Red.
1helpful
2answers
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Radio on 2013 Chrysler 300 keeps changing stations in ascending order
Have you turned off the power to the radio completely? This
can reset the standard operations...(turn radio off while car is on) then back on again...Hope this helps.
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
How to lock in radio station on kenwood face off cd player
once you have the station you want to listen to on the radio press and hold one of the buttons along the bottom of the stereos face for a few seconds the screen should flash for a second or two or it should beep as well to indicate its saved it.
if when you turn the ignition off and then turn it back on the stereo has forgotten the station you programmed you need to remove the stereo from the car and check the wiring at the back of the unit. most of them have a red and yellow wire that are joined by metal push fit connectors, swap these two over and it will then remember the station for you.
the red wire is the switched power lead from the ignition and the yellow lead is a constant live feed for it to remember your settings, if these are round the wrong way it will keep forgetting radio stations you program until you switch them over.
hth
2answers
How to set radio stations
if you don't have all the power wires hooked up it won't save the stations, you should have a low volt wire just for memory status.
Poor cound quality
does the XM use a radio station for recieving the sound or is it wired in to the vehicle. if you have to set a radio station so you can use the XM then what you can do it set the station to some other channel. it maybe to close to a real radio station or the frequency it to weak and you'll need a stronger signal
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
