Question about Gateway Computers & Internet
Cant find how to put the side bar - Gateway Computers & Internet
  • 83 Answers
We are talking Vista right and not mac. If your talking about the Vista side bar then heres how to do it.
  1. Vista start menu (windows icon on the bottom left corner)
  2. control panel
  3. Appearance and personalization
  4. Windows side bar properties
  5. check "start side bar when windows starts". You can also customize it from here.
Posted on Jul 27, 2008
Cant put chain bar back on my poulan chainsaw
Deborah there is a tensioning screw on the side assembly that will need reducing back. This should allow the bar and brake assembly to go back on
Mar 27, 2014 | Poulan Garden
Tryed to put on a chain cant get it back togather right
Completely loosen the chain tensioner. When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. Fit the chain on the bar.(ensure that the chain travels in collation with the sprocket at the end of the bar if equipped). When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. With the chain still in the bar, fit the 5 or so links in the sprocket on the powerhead, engage the bar with the bar nuts, then lastly engage the chain in the tensioner. Place the sprocket cover and nuts. Tighten nuts then loosen about .5 turn. Adjust chain tensioner. Retighten nuts. See that tightening the nuts made your chain tighter, loosen nuts readjust chain, tighten nuts. With gloves on and the chain brake disengaged please ensure the chain travels around the bar. Put on your chaps and start cutting.
Sep 11, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I need to remove the driver side axle and i cant get it out of tranny
There is a "C" clip that holds it in there. Put your pry bar on the fat part of the halfshaft (axle) and give it a few smacks with a hammer. These jolts should knock it loose to be able to remove it. If you cant get room to hit it with a hammer you will have to use a pry bar and just keep working at it on both sides.
Jan 15, 2011 | 1996 Dodge Neon
Helloi have a Maytag Plus side by side refrigerator (about 10 years old) and I'm having trouble keeping the refrigerator side cold enough. This unit has dual slide bar controls on the ceiling of the...
remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Jul 19, 2010 | Refrigerators
The belt slipped
The belt has probably slipped down below the carrier, it's easier to take the shaft out, install the belt then put the shaft back in. Be sure to turn the shaft top to the front with a 1/4 in. wrench to lock it in place.
Apr 14, 2010 | Lexmark Wheelwriter 1500 Typewriter
Trying to reinstall the roof cargo racks on the rails of a 01 jeep cherokee my son took off and cant remember to put on
That's usually easier to do if you remove one side rail.
There are usually six access holes in the rail that the screws go into. (pretty sure the screws are torx type) Once the rail is off, you can easily attach the cross bars and re-attach the rail to the roof. Ends of cross bars are held on with a screw that goes in from the bottom side. When replacing roof screws it is good to put a dab of silicone sealer on each screw hole to prevent rust or leaks.
Dec 29, 2009 | 2001 Jeep Cherokee
98 Honda Accord timing belt change, how do I keep engine from tuning while loosening crankshaft pulley?
this one has the engine on the other side so you cant use the starter motor with a big bar wedged in the chassis just like honda 4wd whatever its called,so last one i done i removed the starter motor and put a crowbar onto the ringear and held it whilst a friend who just happened to be passing pulled on the bar
Oct 30, 2009 | 1998 Honda Accord
I have some icons from the widget bar on my main screen and i cant move them around or back in the side bar? i can still go in to the icons but just can't move them.....
I HAVE the same dam_n problem and its frustrating!
cant put the widgets back left !
if you found the solution please mail it to me
it would be really helpful couse im googeling right now in search for the solution and had no really luck finding it
Aug 14, 2009 | Samsung S8300 Ultra Touch platinium-red...
Assembling a bicycle without instructions
I'm not sure what you mean. . .a common problem is that there is a right-side and left-side pedal. Make sure you're putting them on the proper sides--and the left side pedal screws in the "wrong" way. The "lefty-loosey, righty-tighty" rule is reversed. (This keeps the pedal from unscrewing itself while you ride.)
If this isn't the problem, please post more info.
Mar 02, 2009 | Bell Sports Bell Basic Bicycle Tune-up Kit
I cant put my surpatian belt back on i would like to know how to release the tension on the fan belt on the 1994 buick lesabre custom in order to replace the alternator
Put an 18mm, or whatever size is correct, socket on 1/2" drive bar, or ratchet , and put it securely on nut in center of tensioner pulley. Standing in front of car, you need to pull it upward, with bar on right side, or from passenger side, pull toward you with bar pointing upward. If no socket, try a long wrench same size that will fit on nut good & snug, be sure in each case to pull as straight as possible to avoid wrench slipping off.
Feb 16, 2009 | 1994 Buick LeSabre
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
