I have a Dynex motorized VHS -C cassette adapter with a tape in it. The switch that opens to eject the tape seems to be broken, it just slides back and forth. Is there any way I can get the tape out without damaging it or further damaging the adapter? I'm thinking if I can get the tape out maybe I can fix the switch.
did you ever get solution on this? I have same issue. can you email me response [email protected]did you ever get solution on this? I have same issue. can you email me response [email protected]
You can't post conmments that contain an email address.
You must first put on the battery so that the mtor reurns back to the return mode so that the VHS-C can be placed . Once the door is shut after placing the cassette, the tape is wound up and it becomes just like a regular VHS tape. Now if this is not happening there is always a small gear on the back side with which you can manually wind to bring it up to the desired level. If not the motr is stuck or the pulley is running loose. You can open up and check inside , it is a simple mechansim with a switch to activate and return. Check the motor and gears. reset the drive by removing, check the battery voltage to the motor and your adapter will work. hope you check this out. Good day
Please check to see it the battery on your adapter is worrking fine. Or else replace the battery . If mechanical type load up the tape before you load the cassette to the player. If this ejects again the adapter is not landing well into the mechansim. cleck within the tray for any foreign bits that is preventing the adapter from loading. Also if the end sensors are detecting , use a tape to cover the inner hole of the adapter. if the tape is tight in the adaptor- check for free state by turning with the finger.
If your regular tapes are playing well then you will get the fault without much of an issue but recheck on these tips. Helpful? good day
That may be what you will have to do, in this case, unless you can somehow get that switch to work. I don't understand why the motor continues to run, but it's probably a broken plastic piece or other gear part that's not functioning. When you take the cassette apart, try to look for any broken parts, or loose components that you can reseat. You may have to end up buying another adapter. Wish I knew more to tell you, but that's all I can think of.
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works.
Please rate this solution if it does.
