Question about LG Electronic Window Air Conditioner
How do you clean the drain port on a LG 24000 air conditioner window unit
Help
  • robin565 Jul 27, 2008
    Hey, thanks so much. You must be a teacher. You make it sound so easy. And yes, that is exactly what our problem is.
  • 3 Answers
Not sure if this is what you're looking for, but if it might help... I just posted this on a similar issue (water buildup in the front of the unit and/or a rattling noise when the fan is running - sounds like it's running through water and it's spitting water out of the vent). I'm guessing that it's designed similarly to other LG units...
If the unit has been working fine for a long time and then you suddenly have this issue, the angle you have the unit set at is probably fine, but you probably have a blockage of dirt/mud/sludge/whatever that is keeping it from draining properly. Here's what you have to do...
For safety... turn the unit OFF and UNPLUG IT.
Open the front gate and remove the air filter. Next, remove the entire front gate from the unit (probably at least one screw to remove first - mine was in the middle, just under wher the bottom of the air filter sits). With the gate removed you should have access to locate your blockage problem.
There is a hole that allows the water to drain from the front of the unit (the part that is inside your house) to the back of the unit (the part that hangs outside your house) and eventually out of a drain hole in the rear. Chances are that this hole is clogged. So, when the water fills up in the front drip tray it has no access to drain to the back. Consequently, the water builds up in the fan area which causes the rattling noise and the water being picked up by the fan and blown out of the vent. If left too long, it will overflow the front drip tray and make a mess in your house.
On my unit, the hole was on the far left side (if your are in your house and facing the AC unit) of the drip tray. You can use a piece of coathanger wire, or some other long thin instrument to push the blockage through to the rear. Once this pathway from the front of the unit to the back of the unit is clear, your problem should be solved. You will probably still get the sound and water sputter out of the front for a little while until the water that is in the fan area drains/dries out, but it should return to normal soon.
It is probably best to actually remove the unit from the window and take the cover off of it and really clean it out, but that is obviously a much more involved task. If you have a hose, that's fine and will help. Water won't hurt the unit - just keep it away from the electronics (the controls/display/cord). You should also be carful not to bend any of the tiny metal fins... that's just as bad as (actually worse than) being blocked by dirt/dust. And obviously, allow the unit to dry before you put the cover back on and put it back in your window and plug it in to run it. If you are willing to put in the extra time and effort, you can do a more thorough cleaning job, which would help to prevent the problem from happening again too soon. There's no way to prevent dirt/dust from building up in the unit. Once water/moisture is added to the mix, you're dealing with mud/sludge, which is going to eventually block that small drain path. The only solution is to clean it out once in a while.
I figured this out the hard way. I took the thing out of the window cleaned it (not as thoroughly as I thought) and put it back in and then did it all again. The third time I actually found the hole that was blocked. If it hadn't been such a pain taking it all apart and cleaning it the first two times I would have laughed at myself for missing it.
Good luck! Hope this helps!
Posted on Jul 27, 2008
  • Anonymous Aug 31, 2016
    THANKS!! The coat hanger kind of worked. So I blew some compressed air through the hole and it now flows freely.
I have a lg l8010er and here is how i did ithow do you clean the drain port on a LG 24000 air  - da5885b.jpg inserting bbq skewer
3c6e716.jpg and moving it in and out a couple of times and all done took me 15 mins to find the hole but i found it!
Posted on Sep 07, 2010
Ge 24000 throws beaker not breaker on unit cord
bad breaker or exceeding its amp rating. a 2 ton window units pull alot of amps on start up.
Aug 13, 2014 | GE 24000 Btu Room Air Conditioner EnerStar...
I watched pornn on my moms computer and i can't clear history!!!!
Don't watch stuff you aren't supposed to watch in the first place.
Apr 09, 2017 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
Printer doen't work
Need more info whats wrong??Leave more info in comments or call 225-290-5733 Thanks
May 02, 2014 | Office Equipment & Supplies
I lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow help mei lost my bassword sow...
You made a mistake, you lost your password. Learn from this, whenever you create a new password write it down where you can find it when you need to.
Dec 22, 2013 | Video Game Consoles & Games
LG Electronic Window Air Conditioner Logo
1,498 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
