Question about Brother HL-2040 Laser Printer
Hl 2040 brother hl-2040 after refelling tonner empty light is on and can not take a print
  • 138 Answers
You must have refilled the first (starter) cartridge or didn't reset the toner reset lever. There is a reset lever on the left side edge of the cartridge. Look at the left end of the cartidge (not the fill cap end) for a round white gear end and a white lever in a hal moon shaped slot. If you can see only the round white gear and the hlf moon is emty of a white lever, it's a non-restting starter. If you have two white spots we will be addressing the one in the half moon slot. The used cartidge will have the lever at the "3 O'clock" position. To reset the cartridge as new you must remove the two screws on that end cap and move the lever to the "11 O'clock" position. Put the scews back in and reinstall in the printer. The sweeper lever will turn in the machine and reset the toner count.
***Important For Brothers**
Make sure when refilling that ALL WASTE TONER is completely cleaned out of the cartridge before adding new toner to it. Brother re-uses its old waste toner and over time the toner hopper gets contaminated with paper dust and too much old toner inside causing them to fail. It you just add toner to the cartridge without thoughly cleaning out, you will soon have a bad cartridge again. You'll see it when dumping out the old as white specks in the toner. That's actually contamination from paper dust and talc from the paper.
Hope that helps you.
Posted on Aug 26, 2008
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
Tonner light wont go out
Hold the go button while you power on, when all 3 LED's are on release the go button.
Press the go button 2 times, when all 3 led's turn on solid, press the go button 5 times.
All done...
Sep 01, 2009 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. One whole side of the printed document is faded and blank. How can I fix this problem? I am making the assumption that the toner is not empty since the light is not on. Is...
I wouldn't assume that you aren't out of/low on toner.
Try taking out the toner cartridge and tap/shake it to disperse the toner that is left in it. If that changes the way it is printing, it is about time to replace that cartridge.
Jul 07, 2009 | Digital Products Brother HL-2040 Laser...
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother 2040
Tonner light is blinking means that the tonner life is end.
The other problem come from usb cable change the cable.
Jan 21, 2009 | Brother HL-2040 Laser Printer
Lost Installation CD for my Brother HL-2040 printer
Where Can I download installation software for Brother HL-2040 printer
Sep 13, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
408 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
