Question about Compaq Computers & Internet
I am trying to connect my laptop threw the tv i have the correct lead hooked up and i press fn and f5 the laptop screen goes blank but it does not come up on the tv if you can celp that would be very good thankyou
  • 3 Answers
I know on my tv i have to hit the imput key on the remote to switch it over to the rca plug ins. dont know if you have tried that.
Posted on Jul 27, 2008
I try to connect my pc with my tv with an hdmi cable 2m but my tv can't read it,so when i turn my tv channel to the hdmi port(tv) which i have connect the cable the screen of the tv is blank.in other words...
Once you made all the proper connection, meaning the hdmi cable from your laptop to your tv, and tunning your laptop to the right hdmi port (like hdmi side, rear1 or 2 however many hdmi input your tv has). Then I believe on acer model, you need to press the FN button and the F5 button at the same time that switches your external video source, Leave the Fn button press and then slowly press the f5 button key until your screen is display on the monitor HDMI. Like said earlier, you need to make sure the tv is tuned to the correct HDMI port.
Jan 30, 2011 | Computers & Internet
Cannot connect acer laptop with samsung lcd tv
Dear Sir,
Welcome to Fixya
Solution:
Generally in all lcd tv you have to select input source in TV menu settings,if TV taking input from AGP,you have to select input as AGP ,if it is composite,select source as composit,if it is RGB select RGB as input by using your TV remote.Then press Fn+F5 in your laptop.
I think it helps.
if you have any problem regarding this issue leave a comment or feedback we were happy to assist you.
Have a Nice Day!
Oct 03, 2009 | Samsung Televison & Video
My tv is just blank after adapter is hooked up
Yes,but you may need to press the Fn+F7 or FN+F5 keys on the laptop or go into the control panel and enable presentation mode
Jul 30, 2009 | Toshiba Satellite L305D-S5895 Notebook
I have an acer aspire 5100 and am trying to vue my screen through my tv. I have a vga lead connected to both but my fn F5 button doesn't seem to switch my screen from 1 to the other? can you help
you need do
1) set your TV interface to PC port
2) connect the cable (you are sure it is a good condition) between laptop and TV
3) power on laptop boot system and then hold Fn and click F5(screen change), maybe click 1 or 2 times if you see LCD black and then next to TV screen.
hope help you do it well
May 11, 2009 | Acer Aspire 5100 Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Screen picture froze, powerd down, powerd up, blank screen
open cbinet of crt,
then internally check circuit connection.
or check for external lead connect very well or not ,one of power,and data cable.
Jan 25, 2009 | Acer Aspire 5100 Notebook
Laptop screen went blank while trying to connect to tv
Try holding the FN key and push the F7 key.
If that don't work,Try the FN and F5
please rate this solution
Jan 16, 2009 | Toshiba Portege 7100 Notebook
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
How can I view my Del Laptop screen on my 50" Insignia TV?
do you have the connector.to connect both the units.
Aug 29, 2008 | Televison & Video
Blank Screen
try to press fn and f5 probably the output was set to external video.
Jul 17, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
