Question about Nitro BMW-481 Car Audio Amplifier
1200w Nitro amp
When I plug in my red and white connectors in the amp, the subs start to pulse and the connectors are sensitive whenever I touch them. One guy said that the shield ground could be broken
  • 45 Answers
Yes it could be your ground..check your negative from the amp is going to the car body and not the battery. also try a new set of rca leads from the stereo to the amp..also check that your stereo audio out voltage is the correct voltage for the amp inputs.
Posted on Jul 27, 2008
My red light wont cut off
are they subs or door speakers? if they are subs, then speakers ohm load is too low for the amp. If they are speakers then again the ohm load is too low or one the speakers are blown are shorting out against the door. sometimes when mouting speakers in the door, the terminals are accidentally touching some metal inside the door.
Oct 27, 2014 | Sony Xplod 1200W Car Amplifiers
Power light flashing
This means it is blown. Whenever the power light flashes on any amp it is blown or something else is wrong with it. Most likely its blown. You can blow am amp by hooking it up to a powerful sub and blaring it, or just overheating it. Hope this helps. This can usually be fixed as well
May 07, 2013 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
Is two comp 12's with a 1200 watts nitro amp a
The 1200w rated for the amp is usually an absolute maximum output, the rated output is more likely about a quarter of this figure (300w) I think for the subs you are looking at, you would be better off with a more powerful amp
Hope this helps
May 06, 2011 | Kicker Car Audio & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Honda 1992 XR600 miss firing
Hi and welcome to FixYa,
Initially if electrical, disconnect the black/white wire from the engine stop switch, try and observe if problem persists:
  • if yes, then a loose / dirty / faulty engine stop switch;
  • if not check:
  1. 2 connectors to CDI;
  2. connector from pulse generator (black/yellow - blue/white & green/white wires);
  3. black/red wire from exciter coil;
  4. blue/yellow & green (to ground) wires on the ignition coil;
  5. sparkplug wire & cap.
Good luck and thank you for asking FixYa.
Aug 03, 2009 | 1994 Honda XR 600 R
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
THERE IS NOT 2 RCA HOOK UPS FOR THE SUBS HOW KAN I HOOK UP MY AMP SO MY 2 12S WILL HIT
If there's only a single sub-out RCA cable, you have two options. The amp may have a manual switch that puts it in Mono mode, in which case you only use 1 of the 2 RCA jacks. The other option is to go get an RCA splitter. This will take your single sub-out cable and feed the exact same signal to both left/right of your amp. Either way, you get the same result. If the 1200W amp is for your sub(s) only, you should set the high-pass filter and subsonic filters to help your bass "hit harder" and cleaner.
May 17, 2009 | Dual XDVD8182 Car DVD Player
Nitro 1200w amp
It sounds like the shield ground in the amplifier is broken. If that's the case, the connections would have to be repaired.
Let me know if you have any other questions.
Jul 26, 2008 | Nitro BMW-481 Car Audio Amplifier
Was a green light during the day the next red and stays red
look for wires that are touching each other like speaker wires or you may have a blown sub
Mar 14, 2008 | Nitro BMW-486 Car Audio Amplifier
Nitro BMW-481 Car Audio Amplifier Logo
143 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
