Question about Sanyo Heating & Cooling
My reverse cycle air conditioner wont get hot??? it works fine on a/c but not warm
  • 143 Answers
Sounds like an electrical problem. The only part that is supposed to work during heat, but not cooling, is the reversing valve. That could be physically stuck.
All other ways to cause this problem are electrical. You will be getting in ther with your volt meter to solve this problem.
Posted on Jul 27, 2008
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
We have a reverse cycle LG air conditioner - blowing hot air and not cold and water not coming out of outlet at system
Check your settings on the remote control. If is working on the heating mode it will create condensate water in the outdoor side.
Feb 27, 2011 | LG Heating & Cooling
Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
Dec 29, 2010 | LG Heat cool Window Air Conditioner
HEATER NOT WORKING PROPERLY (SOME HEAT BUT NOT HOT) COMPRESSOR NOT RUNNING WHEN IN HEAT MODE. A/C WORKS FINE.
No adequate heat due to wrong setting temp or your RV (Reversible valve) not working properly.
Set temp +5 than your room temp and mode in " Heat". And check click sound in reversible valve and also warm in sunction line.
If it's with heating element check power goes heater coil. If not check wiring.
Dec 27, 2010 | Heating & Cooling
Reverse Cycle not cooling!
I had a service man come out and he said the compressor was not coming on so he installed a hard start in parallel with capacitor solving the problem and is working normal now.
Nov 30, 2008 | Heating & Cooling
Reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Nov 07, 2007 | Kenmore 71121 Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
99 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
