FixYa.com
Tags:
Dryers
Generic problem for all Maytag Dryers
Maytag Dryer quit running
posted by BkWoman5 on Jul 27, 2008
I put a load of clothes in the dryer turned them on like always, dryer ran for about 5-10 minutes and quit. Clothes were warm inside...dryer just quit running. I clean my lint trap every load so I doubt that could be a problem.
Checked the dryer plug in and it was not completely plugged in so I pushed it all the way in, still nothing. Checked the breaker, it looked good, but I flipped off and on just to make sure. Does this sound like an expensive repair?
Comment by BkWoman5, posted on Aug 01, 2008
The dryer is pretty new, but a basic type model.
We did take the dryer partially apart and vacuum it out.
Belt looked good, didn't see anything that looked loose or burnt.
I am guessing from what I read that it is going to be the thermal fuse.
Called Sears to schedule a repair. If the repair is too expensive you pay the $65.00 technican fee, but get a coupon for $65.00 towards the purchase of a new dryer as long as it is over $399.00. So that's my plan.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 27, 2008
Helpful (85)
mineral02
Rank:Apprentice Apprentice
Rating: 81%, 4 votes
If your not a handyperson, this could be expensive...
a)  you didn't tell us if this is a newer electronically controlled dryer, or just the old reliable type...  newer types, in my opinion, will generally have more controls fail than the older types, but sometimes something on the older types fail also...  to replace the newer stuff will cost lots -- cheaper to buy an ol' reliable...
b)  besides checking the lint trap, you should periodically inspect the outside vent to make sure the airflow is good...  also, it's always a good thing to take apart the dyer every now and then and clean it out if the dryer has run a lot... in most cases, the dryer would be replaced before it really needs to be cleaned out (I kept mine for many, many years)
c)  in the dryer heater duct, there are a number of safety switches -- if for any reason, the dyer air should over heat, it shuts down the dryer -- some are resettable, some are the replaceable type, but both types will be used; unfortunately, even if a resettable switch operates, the replaceable will almost always operate...
d)  since it appears nothing works, I suspect the heating element is still probably good, but...
e) if the breaker was not tripped, then the motor is probably OK...
f)  I'm not sure, it's been awhile since I've had my dryer torn apart, but I think it will also shutdown if the drum drive belt breaks...
My suggestion is to call a trustworthy repairman, determine the potential costs up front and then decide whether to replace or repair... or call a trusted friend to fix it if they have the knowhow...
Rating Locked! (?) BkWoman5 has rated this solution as Helpful
This Problem Also Relates To: Maytag MDE8600AY Electric Dryer Maytag MDE9206 Dryer Maytag MDG9606 Dryer Maytag MDE508DA Dryer Maytag MDE9316 Dryer Maytag MDG7600AW Gas Dryer Maytag SDG5401AWW Gas Dryer
Can you Help with these Dryers problems?
Zanussi TC180W Electric Portable Dryer
drum turns in my dryer,but no...
Hi Guys ! Im a single United... Answer This...
Whirlpool GEW9200L Electric Dryer
My GEW9200 will not power up,...
Dryers
Getting E62 error
Getting E62 error Answer This...
Dryers
dryer model drcs68w start light
dryer model drcs68w start light... Answer This...
Asko T700 Electric Commercial Dryer
Asko dryer now makes alot of...
I have had my Asko for about 1... Answer This...
Repair Service
Find Dryer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
