Engine overheating
No water pump issues I am aware off, are you sure you bled the air out of the cooling system? If not fill the overflow bottle all the way full, then use a floor jack and raise the front of the car as high as you can ( this allows air to go to top of radiator tank), then run the engine at high idle speed until the cooling fan ( I assume the fan works OK?) comes on, but avoid letting the engine get into the overheat area of the guage, if it does turn it off, run water over the radiator until it cools, check the tank and radiator, top off if you need to and repeat above procedure, if this doesn't work you have some other problem like no or little flow in radiator.
