Question about Fellowes P70CM Shredder
How to disassemble Fellowes P70CM Shredder
I removed 6 screws and the unit does not come apart. Is there a trick to it?
Agreed, there is a seventh screw under the label, as wstrooper suggests. Press along the label and you'll find the tell-tale indentation!
Having taken it apart (a further 4 screws to remove the nylon housing from the base, and another seven to remove the nylon covering for the gears), it has revealas a stripped gear (the one nearest the motor), caused by too many sheets of paper being fed in.
This problem seems to repeat amongst several P70CM owners. Shame the motor doesn't have a cut-out if it hits too great a resistance, rather than strip the gear of its teeth.
Posted on Apr 02, 2009
Theres another screw under the label in the middle
Posted on Sep 05, 2008
    Problem Solver:
  • 4 Answers
In addition to the seven screws, you have to remove the on-off switch lever. You pry it off -- it takes a lot of force. Use a screwdriver, wedge it under and pry, then move around switch, orying a bit each time.
Posted on May 23, 2009
I called Aurora at 1-800-327-8508. I explained my shredder's motor ran, but the cutting blades no longer rotated -forward or reverse. As it was past warranty I asked how to disassemble the unit.
The operator listened to the sound and diagnosed one or both nylon drive gears were stripped. She took my
model number- AuroraAS650C
date of purchase- I estimated it to be after 2006
I ordered the gear set on the phone for $10.
She told me there are 6 obvious screws recessed about 1 inch each on the bottom of the motor/cutter housing...
and one hidden screw under the small oval label.
UNPLUG THE UNIT. DON'T PLUG IT IN TO TEST UNLESS YOU HAVE A WORKING KNOWLEDGE OF ELECTRICAL APPLIANCE FUNCTIONS.
Carefully remove the top of the housing as the paper sensing rod can fall off the unit. I put a couple of pieces of masking tape across the top to hold it in place.
The cutters and motor unit are held onto the bottom of the housing with four screws. They have to be removed to get to the drive gears which are covered by a plastic housing. That cover is attached with screws of varied lengths, so remember which screws went where.
Once the gears were exposed it was easy to remove both nylon gears that had been damaged. Remember the order and direction of the gears.
I await the mail now to see how it all goes together.
If you don't like to tinker and repair material goods to reuse, a new similar unit is around $35 to $40. Plus, you may help kick start our consumer economy.
Roger M Zander
Posted on Jan 18, 2012
  • 797 Answers
You may have to pry it apart, if you have removed all screws.
Posted on Jul 28, 2008
Paper Jammed
I have had the paper jam in my shredder which was not a Fellowes. I removed the power plug from the wall and used old dentist tools to pick the pieces of paper out of the shredding mechanism from underneath. I did not need to remove the cover. After extracting some paper try using the paper reverse option.
Apr 02, 2014 | Fellowes P70CM Shredder
Plastic got in shredder won't work,would like instruchions to take it apart to fix
Take out the paper bin. Look for and remove any screws holding the top part of the shredder to the base. Take the top off, turn it upside-down and you might be able to remove the jam. To take the top apart, remove all of the screws that are under or near the edge. Look out, it gets very messy when you take it apart!
Fellowes sells replacement gears for some of their shredders.
Mar 30, 2014 | Fellowes Manufacturing Powershred SB-97CS...
We have a p600c-2 shredder and it will go in reverse, but it wont work in forwards. we have taken it apart, and we think the problem is the little switch inside. please help?
I had the same problem with my shredder. I removed 6 screws and the cover of the on/off switch. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism so it operated freely and reassembled the shredder. Hopefully this will work for you also.
Dec 04, 2010 | Fellowes P600C-2 Shredder
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
OD700C Fellowes Shredder blades don't turn
There is a screw hidden under one of the stick on labels. Remove that and the top comes just fine. I got it torn apart, completely cleaned of debris but the rollers still don't turn. I noticed an electrical arc when the switch is pressed so the unit is toast.
Feb 22, 2010 | Fellowes OD700C Shredder
My Fellowes p600c-2 shredder will only run in reverse. I've blown compressed air on the switch and pushed on it with a toothpick but neither method worked. I removed 6 screws and the cover of the on/off...
Never mind providing help, I fixed it myself. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Jan 17, 2010 | Fellowes P600C-2 Shredder
Fellowes Paper Shredder P70CM paper jam
Clean the upper and lower sensors with a cotton swab moistened with rubbing alcohol.
Jun 21, 2009 | Fellowes P70CM Shredder
Auto shut off
You may want to examine the unit carefully and remove the screws which hold the unit together, you will find these screws on the bottom. Either there may be scrap over the switch or sensor or the sensor or switch has been broken. Clean the unit as best you can. You may be able to find the problem from your examination.
Jul 26, 2008 | Fellowes P70CM Shredder
Fellowes crosscut shredder does not shut off
I got an email from Fellowes technical support suggesting I use alcohol and a cotton swab on the sensors after unplugging it. That fixed my problem.
Nov 16, 2007 | Fellowes DM8C Cross-Cut Shredder
Fellowes P70CM Shredder Logo
4,972 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
