Reset your operating system software (Windows XP..)to Compaq factory setting : restarting your computer. Hold down F10 key, your computer will go into recovery software provided windows recovery was preloaded into your hard disk during installation.
Follow on screen instruction.
If it your Bios you want to restore to factory setting, restarting your computer hold F1 key, entering BIOS set up. Look and press the key assigned "Default Loading" save change and exit Bios set up.
Does that solve your curiosity
SOURCE: factory settings without the cd rom disk
Default behavior of Windows XP is that it automatically logs in if there is only one user account in the system and is not password protected.
Here is a way to make XP automatically login to a user account.
By default, it shows Administrator. You need to input your username and password.
Delete any account you don't need
Please take time to rate this fixya
SOURCE: how do u reset a dell computer back to factory setting?
if your computer shows a blue bar at the top of the screen and says www.dell.com you can try ctrl+f11 which will start the system restore sequence......hopefully you have one of the dells which containt this feature
SYSTEM RESET
Warning - You may loose all of your saved files - Back-UP first!!
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you may loose all of your files and after market downloads.
Back-UP first!!
That's worth 4 thumbs up!
Do you have a recovery partition?
If you do you can try to run the recovery tools and there should be an option to set back to factory settings. Another option is to do windows system restore. Although a system restore won't put it back to factory settings, it can improve the system.
This guide is pretty good:
http://www.howtogeek.com/howto/windows-v...
